Alarm randomly goes off.
Old Jul 12, 2019 | 01:03 AM
Adam73bonner's Avatar
Default Re: Alarm randomly goes off.
Originally Posted by Adam73bonner
Hi what fuse is it to pull to stop the alarm going off please
Thank you
Old Aug 4, 2019 | 06:09 PM
beastwithin's Avatar
can you remove the alarm module and replace the fuse to be able to lock the doors again or do you have to replace the module?
Old Aug 6, 2019 | 04:17 AM
I'm not sure but over night I removed the fuse to stop it going off but it's such an easy job buy a secondhand one from sites
like Ebay and others I bought mine for £30 it takes 10 mins to replace
Old Aug 6, 2019 | 06:32 PM
problem is wife is out of work and we are low on cash at the moment. fuse has been pulled just would like to be able to lock my doors and hatch.
Old Aug 6, 2019 | 11:51 PM
Disconnect the siren, simple fix.
Old Aug 7, 2019 | 01:13 AM
Ok then the best thing to try is to undo the cowling skirt around wiper arms think there are 6 hex screws then undo the alarm module take it out or leave the wire dangling there not tried it myself but it may allow you to lock car not sure but as I say it's only about £40 off an auction site you must be able to afford that as these cars are real fuel guzzlers
Old Aug 7, 2019 | 10:37 AM
Disconnected everything works as it should just as long it is the siren causing the problem.
Old Aug 7, 2019 | 05:19 PM
You should be able to tell if it's the siren as it sounds distorted sometimes or even as if it's being strangled
Old Apr 27, 2021 | 06:15 AM
Bilaal's Avatar
Originally Posted by mhmerrick
My siren has been weak for years no on my 04. Yesterday the fob wouldn't open the car. Opened with the key and the alarm lights started. It didn't stop with the fob or inserting the key. When it stopped I started the car but it quickly died. Then it would not turn the starter at all. Saw in another post to remove fuse #9 to disable the domelight, horn and alarm. The light went off, but the horn and the alarm both still worked. Replaced the fob batteries, no help. Had no tools at work so I called a tow truck. He tried to jump it to no avail. At home I found a post and decided t follow the suggestion to take the 10mm to the negative and disconnected and reconnected the battery. I could not start now since the battery was low. Put on the charger for a few minutes and it started .Drove 38 mi to work where it restarted fine. Did not lock the car. 10 hours later it started and drove home fine. I am going to try replacing the siren next. So glad all of you are there to help figure out these issues. The local dealer quoted $8-900 to replace the SKREEM but it seems the siren is the problem from what I have read here in the forum.
I had something like this happen to me with my once..
I changed the batteries but it still never helped. I found a post somewhere on the internet on how to link the fob to the crossfire again... something about inserting the key in the ignition and turning it once and pressing a few buttons...
Did that and it worked
syfi
Mar 28, 2026 04:14 PM
vnrcoop
West Forum
Oct 4, 2018 01:09 PM
Franc Rauscher
May 9, 2016 12:04 PM
Sterling57
Apr 11, 2016 06:11 PM
Mackel
Oct 16, 2015 09:03 AM
