Electric seat problem
Old Jul 12, 2014 | 07:56 AM
bullspc5's Avatar
Default Electric seat problem
Hi can anyone give me some advice about electric seat problem on my 2004 crossfire. I bought the car and the seats were not working at all. I changed the relay for the seats and all worked fine for about 15mins, then the drivers side stop working. Passenger one working ok still. I still got to double check the fuses but wondered if this was a common fault. Many thanks jason
Old Jul 12, 2014 | 08:16 AM
Default Re: Electric seat problem
Not only common, but UNIVERSAL !
see : https://www.crossfireforum.org/forum/323595-post11.html
Old Jul 12, 2014 | 08:51 AM
The fuse is probably the cause, in this case fuse #22 for the drivers seat.
Fuse #21 is the passenger seat.
Old Jul 12, 2014 | 10:50 AM
Dave, I don't see it that way. Seems to me that fuse #1 tells the module that the ignition is on, fuse #24 supplies the voltage for BOTH seats :
( Am I looking at the wrong service manual ? )
Old Jul 12, 2014 | 11:07 AM
turbomar's Avatar
That's the heated seat crct diagram. I believe the OP is talking about the power seat part of it
Old Jul 12, 2014 | 11:09 AM
Well then, that explains it. Don't know why 'heated' popped into mind.
Carry on.
Old Jul 14, 2014 | 03:57 PM
bullspc5's Avatar
I have just checked fuse and 22 has blown. It is a 30amp one which I changed and seat worked for a few seconds then blew fuse again. Can anyone tell me the most probale cause. Only a problem on drivers seat. Thanks.
Old Jul 14, 2014 | 05:23 PM
If the motor does run for a few seconds before the fuse blows, it is most likely the motor itself.
There's 2 ways to find out :
1. Replace the motor. ( swap it between the seats, lot's of work but you'll be able to clean up those 10 year old buggers that have been hiding under the seats. )
2. jump the fuse with a big *** wire and look for smoke : MOST DEFINITELY NOT RECOMMENDED !!!!
rfourt
Aug 12, 2020 07:27 PM
ldare2000
Dec 29, 2015 07:57 PM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
michaelcycle58
Jul 28, 2015 08:12 PM
Bifftws
Jul 20, 2015 08:55 PM
