Help!!! Please! Need it badly
Old Jul 30, 2014 | 12:26 AM
stanced E46's Avatar
Default Help!!! Please! Need it badly
2005 Chrysler crossfire non srt model convertible car had issue with random shut off I resoldered rcm and changed cps sensor I also changed valve cover gasket n while I was at I cleaned the mass air flow sensor ok so here's the problem no the car doesn't shut but when braking or coming to a stop the car bogs out idle drops like it's about to die?????!!!! It doesn't die tho thank god anyone knows what's the problem only does it when u brake or start to come to a stop or if anyone from California would like to fix it for me?? Lol its not my car it's my gfs car :/
Old Jul 30, 2014 | 12:50 AM
Default Re: Help!!! Please! Need it badly
Be sure you have properly installed the MAF and air box. Double check your connections.
Old Jul 30, 2014 | 01:02 AM
Yeah I double checked it car only does it when I hit the brake should I double check the rcm? I didn't melt the pins sticking out I just added more rosin solder lol could it b that?
Old Jul 30, 2014 | 07:03 AM
PNA's Avatar
PNA
I'd check the vacum lines, the fuel filter / pump, and as previously noted, all the connections. It doesn't sound like the RCM but it would be good to check it again.
Good luck.
Old Jul 30, 2014 | 07:10 AM
Cap off the vacuum line to the power brake booster at the manifold.
CAREFULLY see if this resolves the problem - YOU WILL HAVE VERY LITTLE BRAKES !!!
If it does, you probably have a defective power booster.
Old Jul 30, 2014 | 12:47 PM
Anything else u guys would recommend so I check all at once?
rampntlion
21
Feb 11, 2019 08:18 AM
steps
Oct 13, 2015 06:18 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
tritongreen
Sep 18, 2015 07:32 AM
