My turn..Mystery NO START
Old Aug 25, 2014 | 10:35 AM
STEPHENJXN's Avatar
Default My turn..Mystery NO START
Earlier last week Ive noticed my fob wasnt consistently lock/unlocking my doors. I can manually open the doors using the key. I thought no problem..Ill buy batteries for it and this issue will be solved. No hurry. No worry. Drove the car all week. She ran like a top. Put her in the garage this weekend. Got up this morning, placed key in the ignition, turned and......nothing. No Clicks...No Humms...No dash lights...No head lights...No hazard lights. No electronics. I thought...dead battery? Battery is only a year old. Checked both terminals and they are tight and still look like new.
I thought that this may be a RCM issue but at least the electronics (dashlights, headlights) should work. Could it be as simple as a jump start...battery disconnect / reprogram key fob or am I missing something? What would cause the car to die like this or drain the battery (if its the battery)
Old Aug 25, 2014 | 01:45 PM
meh03's Avatar
Default Re: My turn..Mystery NO START
I'm thinking the battery. Test it. I had to buy a charger for mine today. Mine was sitting in the garage with the hood open for about a month and no other electronics draining juice to my knowledge, but it was dead when I tried to start it. I wonder if there is something that continuously drains it slowly.
Old Aug 25, 2014 | 04:03 PM
STEPHENJXN's Avatar
Thats my thought too. What can drain the battery so fast? it only sat in the garage for 2 days.
Old Aug 25, 2014 | 04:44 PM
If your car is a roadster,,,,it could be the trunk light. Be sure the boot hatch is fully closed.
Old Aug 25, 2014 | 10:19 PM
Check the battery cables again
Be sure they are REALLY TIGHT !!!!
Use a wrench and be sure
Mine had intermittent total power failure off and on for 6 months and it was as simple as a slightly loose battery clamp also with a battery only a few years old
Here is one post I made in the thread I had started 6 months previously..........
https://www.crossfireforum.org/forum/678573-post21.html
Old Aug 26, 2014 | 12:08 AM
STEPHENJXN's Avatar
having the battery checked at the local AutoZone just in case. Thanks Valk. Ill make sure the terminals are clean and super tight!!
user 8202
Canada
29
Nov 11, 2015 05:27 PM
xjken
Sep 13, 2015 10:18 PM
lazorouss
Sep 11, 2015 09:16 AM
BEATv1
Sep 10, 2015 12:58 PM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
