Car stuck in Park Cannot Shift? BAS ESP Light on too
Old Sep 20, 2014 | 04:41 PM
autumnmass's Avatar
Default Car stuck in Park Cannot Shift? BAS ESP Light on too
I have a 2004 coupe with 33k miles automatic shift. I just pulled into the driveway and the BAS ESP light came on. I tried turning the wheel to the left and right but light still appears. I also am unable to shift out of Park. Shift seems to locked somehow, would this happen when there is a problem with the BAS ESP? Any help would greatly be appreciated. Thank you.
Old Sep 20, 2014 | 05:12 PM
Default Re: Car stuck in Park Cannot Shift? BAS ESP Light on too
Use the special tool, and if you dont' have it, use a small flat blade (small but LONG) screwdriver to unlock the shift.
I haven't had an auto for three years, but there is a slot you stick the tool in and manually free the shift.
Not sure why the BAS light would disable that shift solenoid...
Old Sep 21, 2014 | 01:42 PM
Mrmiata's Avatar
Brake related input to computer? Since shift release is brake pedal dependent and BAS/ESP is "braking system"... ? Brake lights working?
Old Sep 21, 2014 | 01:54 PM
You put your foot on the brake pedal which will allow you to put the car into gear....interlock....
Old Sep 21, 2014 | 05:08 PM
The guy has not looked at the forum since 5.20 pm yesterday, I'm guessing he has solved the problem and moved on. Pizza man may have solved the problem for now.
Old Sep 22, 2014 | 08:57 AM
autumnmass's Avatar
Thanks Pizzaguy and everyone. I was able to get the shift out of park with tool suggested. Seems to be shifting OK but I intend to replace the brake light switch. Even the BAS light has disappeared.
rayth
41
Jul 31, 2019 04:02 PM
syfi
Jun 22, 2015 07:23 AM
WindRestrictor
Jun 16, 2015 12:18 PM
Nick97
May 30, 2015 08:13 PM
mouserider
Jul 20, 2003 03:42 AM
