help please, no start, lights flash, fob's not working
Old Nov 12, 2014 | 05:48 PM
Speedy4x4's Avatar
Default help please, no start, lights flash, fob's not working
Monday fob had a problem unlocking doors, so I went to O'Reilly and put new batteries in both remotes.
Worked fine, drove 3 hrs to terra haute, drove around terra haute last night, no problems, replaced side marker lights with led, last night, remote locked doors when I went into hotel, got back from work heading to get oil changed and the fob would not unlock door, used the key to unlock and the lights flash and it will not turn over, neither fob will work, tried reaching pairing with no luck.
Cold here 30°
Put a new battery in car around 6-7 months ago.
Any suggestions??
Fob not working, lights flashing, no turn over.
Old Nov 12, 2014 | 06:28 PM
Speedy4x4's Avatar
Default
Originally Posted by Speedy4x4
Monday fob had a problem unlocking doors, so I went to O'Reilly and put new batteries in both remotes..
Problem locking not unlocking, left car unlocked while I went into store, came out car started fine.
Old Nov 12, 2014 | 07:27 PM
Speedy4x4's Avatar
Default
After disconnecting the battery for 10 minutes remote worked so car started.
Just wanted to be careful due to the "30 start".
Being 3 hours from home and my shop & tools every week sucks.
Now I need to know why it did that and what I need to change so it will not happen again.
Old Nov 12, 2014 | 07:45 PM
Default Re: help please, no start, lights flash, fob's not working
skreem module acting up? Or just something weird from changing the batteries.... I hate hearing about these funky problems....but the module could be ready to give you some trouble...
Old Nov 12, 2014 | 08:16 PM
Speedy4x4's Avatar
Default
Since this is the first day temperatures have been freezing i was thinking the Central Locking Pump Module could have got water and froze.
But since I work 2-4 hours from home I need to figure out why and what needs replaced
Old Nov 13, 2014 | 01:49 AM
Mrmiata's Avatar
FOB not working. I'm guessing in both cases not only did it not unlock.. but no flashing lights indication? Water frozen I could see interfering with locks.. but the electronics side should have indicated with the lights. Seems there have been a few lately that needed "disconnected battery resets" and haven't seemed to have any problems afterwards.
Old Nov 13, 2014 | 06:36 AM
Yep, typical symptoms of a CRBFS ( Crossfire Related Brain Fart Syndrome ),
take 2 aspirins, disconnect battery, wait 20 minutes, reconnect and you both feel better.
Old Nov 13, 2014 | 08:50 AM
Speedy4x4's Avatar
Default
The 30 start self.destruct is retarded, I going to do some digging around when I am home this weekend.
I do not have a alarm siren but all the lights where flashing
Old Nov 13, 2014 | 08:59 AM
Mrmiata's Avatar
No siren... Houston.. I think we found the problem...
Old Nov 13, 2014 | 01:53 PM
Speedy4x4's Avatar
Default
Has never worked since I got it, and have not evan looked to see where it is or was at on my 04 6 spd.
Old Nov 13, 2014 | 01:56 PM
Mrmiata's Avatar
Well then sounds like previous owner may have disconnected it.. so that takes out battery and corrosion issues..
Old Nov 13, 2014 | 05:58 PM
Speedy4x4's Avatar
Default
When I had my battery disconnected I also took the battery out of fob's right before I hooked battery back up.
And only pu batteries back in spare fob, incase something happened to my fob I carry around.
This weekend when I am home I will put the battery back in the remote and resync it to the car. To test it
gtjl
17
Jul 22, 2015 06:28 PM
tom2112
Jul 12, 2015 04:41 PM
joethejeweler
Jul 7, 2015 08:58 PM
Blackout317
Jul 7, 2015 08:38 PM
Fildo Dog
Jul 6, 2015 05:20 PM
