trans seeping?
Old Nov 25, 2014 | 12:20 PM
Da55id's Avatar
Default trans seeping?
I've noticed I may have the famous o-ring connector weeping problem. Since the car is 10 years old, and the dipstick cap looks original, would anyone hazard a guesstimate as to how much fluid might have been lost over the years?
Old Nov 25, 2014 | 12:51 PM
Bill F's Avatar
Default Re: trans seeping?
You did say transmission? Crossfire did not come with a transmission dip stick. If it has one someone installed it.
Old Nov 25, 2014 | 01:01 PM
Da55id's Avatar
right. I meant that the cap which sealed the transmission filler tube was still in place. there is no dipstick installed.
Old Nov 25, 2014 | 02:24 PM
Bill F's Avatar
There was a TSB on the leakage and Chrysler fixed it, the car was under warranty. When it started to leak there was a puddle of tranny fluid that wasn't there the day before. I got it fixed right away. It doesn't matter how much is lost as you don't know when the leak started, take care of it before it becomes a real problem.
https://www.crossfireforum.org/forum...ssion_leak.pdf
Old Nov 25, 2014 | 05:17 PM
VQ35DE's Avatar
Fix it ASAP.
Old Nov 25, 2014 | 10:27 PM
Da55id's Avatar
Yep, I understand it needs fixing. I was asking for loss of fluid guesses. Never mind :-)
Old Nov 25, 2014 | 11:20 PM
VQ35DE's Avatar
No way to guess the ATF level. You can buy the correct dipstick on ebay for just $10.
Abaton6
Oct 26, 2016 10:43 AM
minimayhem
17
Jan 19, 2016 02:10 PM
jimf
19
Oct 19, 2015 04:05 PM
rfourt
Sep 25, 2015 01:38 PM
chturner
Jul 24, 2015 04:47 PM
