Throttle is messed up **Video **
Started the car today and same problem.... but then I checked the forums!!!!!
OMG how did I miss that! I'm gonna try and fix tomorrow. Anyone know what the Part # is or a good place to buy a new one?
Hope this fixes the engine problems!!!
It does measure the temps along with flow.. been plenty on "intake temps and mods" posted.. So I don't think I'd put much weight in the grille temp probe.
Are you just revving the car setting still. If so, that is normal. It has a limiter so you won't over rev the engine. Going down the road in normal operation, it should be fine. If that isn't the case, sometimes the throttle pedal will come loose from the mount and slide down a bit, not giving you a full throttle. Good luck.
Blue tooth DRBII module.. torque pro.. you could at least data log and see what's going on to a degree.. Including vacuum and fuel trims.
MAF (P0102) (click) and secondary air codes.
I wouldn't worry about the secondary air code right now.
If you disconnected the MAF and it made no difference then I'd say it's broken. But there again that's the way I look at it, too logically maybe. See my post of five days ago.
I unplugged the MAF and rad fan goes crazy.
New thing found! Clicking or something inside the dash area? maybe something?!
CHECK OUT VIDEO!!
Noise at the end 1min long
[YOUTUBE]
Another question how does the gas pedal work in this car?
Maybe its messed up?
CHECK OUT VIDEO!!
[YOUTUBE]
No problem at all, they just put that part in there for fun. LOL
That O-ring stops unregulated air from entering the engine and ruining the correct air/fuel ratio.
The O-ring is basically a very cheap part, less than 50 cents in bulk. At the dealers it will be $5 - $8, hey they have to put food on their table too you know.
Use a Viton (high temp use) O-ring if you buy one yourself, a normal O-ring may work for a while, just make sure it drops in easily and is the correct size.
Read all this, get used MAF off Ebay for 50 bucks and replace , have you taken look at CPS , Have you pulled ECU and look for cracks on the Board
