No starter turn over
Old Feb 4, 2015 | 05:38 PM
Pinopolis's Avatar
Default No starter turn over
Key in switch, all lights are on and working, battery is fully charged, turn the key, nothing, it does work sometimes, but it is like rolling the dice. It is a 2004, auto. Is there a saftey nurture switch?
Old Feb 4, 2015 | 05:43 PM
Default Re: No starter turn over
What you have is most likely the "Mystery No Start" syndrome.
https://www.crossfireforum.org/forum...tml#post430634
Old Feb 4, 2015 | 08:38 PM
velociabstract's Avatar
Typical RCM fault symtoms. Sorry, but 98% probability. Have someone with electrical soldering experience re solder the contacts or buy a new one.
Les
Old Feb 4, 2015 | 10:11 PM
If this was not a Crossfire there would be other answers to this question;
  1. Some fault with the starter motor like sticky brushes.
  2. Bad cable to the starter motor.
  3. Bad connection at the battery that does not allow high amperage connections.
All of these things can happen on a Crossfire just as well as any other car. On a Crossfire the problem is often the RCM, but look for other problems as well, tunnel vision can be a waste of time and money. Look for the simple and cheapest causes first.
Valk
Jul 12, 2021 09:49 PM
franklindm
Mar 14, 2020 12:23 PM
Sterling57
Apr 11, 2016 06:11 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Valk
Sep 17, 2015 11:43 AM
