Aftermarket key fob car wont start
Old May 3, 2015 | 11:23 AM
CHRGD UP's Avatar
Default Aftermarket key fob car wont start
Hopefully someone has an idea why this is happening. I recently switched out all the parts of my original key fob (transponder chip, blade, etc.) into an new key fob case. The remote operates the door locks but when I try to start the car it runs for about two seconds and then quits. It does this three times and them the starter seems to disable because when the ignition is turned nothing happens at all. I then used the original spare key and everything works fine. What am I missing? BTW, car is a 2005 SRT6.
Old May 3, 2015 | 01:31 PM
Mrmiata's Avatar
Default Re: Aftermarket key fob car wont start
Best guess is the chip is not in the exact same spot as the OEM one? I had one slip back about 1/4 of an inch or so and got to go back in to it for this reason.
Old May 3, 2015 | 01:38 PM
It could also have been damaged when taken out.
Old May 3, 2015 | 01:58 PM
CHRGD UP's Avatar
Thanks MrMiata, turns out the chip wasn't in there at all. It must fallen out when I took the old fob apart and I had no idea it was missing. Fortunately I actually found the little guy. Everything works perfect now. Would have never found it without the replies.
Old May 3, 2015 | 02:36 PM
Mrmiata's Avatar
LOL.. that thought had crossed my mind.. but wasn't going to doubt "you transferred it".. Glad you got it sorted..
Old Jun 10, 2015 | 09:26 PM
46Chiefpilot's Avatar
Just ran into the same problem myself this morning. Last night I had my first encounter with the RCM. Had me stranded at work at 3am. Of course I hit this web site immediately on my phone and was able to get the car to start. Drove home with no issues. This morning I decided to swap my keychain case with one I ordered on eBay (before checking to see if my car would start today). Then went outside and tried to start it with new fob case and did the famous 2x start and stop thing. Thought it was still an RCM issue from last night and removed the RCM and did the solder repair. Reinstalled and same thing over and over. Didn't even register to me to think of the transponder chip. I never swapped it over! Duhhh! Feel like an idiot. I drove my other car to work today so I will swap over the chip in the morning. Should be what is causing the issue.
One thing I have a question about is the locks do not actuate at all when car is not running. Both on the switches at the console and key fob. Key fob will not actuate them in either state (running or not) even with original case before the swap. Any clues as to the cause of this? Thanks in advance.
Old Jun 14, 2015 | 03:26 AM
Swapped out the transponder to the new key fob and everything is working. Found that the fuse was missing under the hood that controls the map light and door locks. So I replaced with proper fuse and now all keyless entry systems work and map light works. Glad I don't have any SKREEM issues.
backinblack
Aug 11, 2015 09:41 PM
droptop
Jun 21, 2015 02:42 PM
mhajek18
Jun 17, 2015 01:35 PM
gobraves423
Jun 6, 2015 07:03 PM
WindRestrictor
Jun 1, 2015 02:31 PM
