what is this part, found in trans pan
Old May 25, 2015 | 02:05 PM
snekeptp's Avatar
Default what is this part, found in trans pan
i found this part in my trans pan when changing the fluid and doing leak fix.
anyone know what this is and where it goes?
Old May 25, 2015 | 05:17 PM
eightball200's Avatar
Default Re: what is this part, found in trans pan
Picture won't load for me but if it looks like a little plastic stopper it's used in assembly to keep dust from getting in through the dipstick tube. Just means that's the first time the fluid has been changed. Again I can't see the picture but that's my guess. Every automatic transmission has one until the first fluid change.
Old May 25, 2015 | 05:57 PM
grip grip's Avatar
Old May 25, 2015 | 06:09 PM
glad to see you are awake Anthony , enjoying the new car I see . jim
Old May 25, 2015 | 06:12 PM
grip grip's Avatar
I was just setting here wondering when you're going to convert to E85.
Old May 25, 2015 | 06:17 PM
don't want to thd jack, but no E 85 just mid 10's is all i ever wanted, now i am there, reliable daily driver and happy,,,(unless some goes faster that my car) lol jim
Old May 26, 2015 | 06:24 AM
ImportLabSRT's Avatar
Its a magnet to catch any metal debris that may enter the pain.
Old May 26, 2015 | 09:41 AM
If you (snekeptp) closed up the transmission pan already, I suggest you open it up again. You DO NOT want to have metal shavings (ferrous metal) swimming around in there.
Please let us know the results!
Old May 30, 2015 | 11:54 AM
snekeptp's Avatar
not used to seeing such and odd shaped magnet. usually just part of or added to the drain plug.
i did not install the pan until i had an answer.
doing a full 100k mile service.
oil done, trans done including new wiring connector to correct leak
waiting on water pump, belt, idler and tensioner.
will do the rear while i am under the car now.
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Jul 28, 2015 08:12 AM
SuperD500
Jul 23, 2015 02:53 PM
Dave Wilson
Jul 18, 2015 05:31 PM
Tp'sfury
Jul 17, 2015 01:15 PM
