Intermittent Losses of Power, Car Shut off and Restarted Immediately
Old May 28, 2015 | 07:19 PM
Cedar11's Avatar
Default Intermittent Losses of Power, Car Shut off and Restarted Immediately
Hello all,
Over the past couple months I have felt a split second loss of power while cruising on the freeway. It also happened once while accelerating around 45 MPH. It is so short that I could not even get my eyes down to check the engine speed. It feels much like the traction control kicked in but much shorter and the traction control light doesn't come on.
Today the car died while I was driving in the parking lot, all the lights were lit on the dash. The car restarted immediately with no issues.
I changed the crank position sensor this past weekend with a brand new Bosch unit. Fuel pump and filter were both changed a year ago. Cam position sensor was changed about 3 years ago.
Any ideas? Thanks in advance.
Old May 28, 2015 | 11:08 PM
Padgett's Avatar
Default Re: Intermittent Losses of Power, Car Shut off and Restarted Immediately
If there is a sudden loss of power, that could the the throttle position sensor, OTOH if it dies compltely I'd suspect either the ignition switch or the SCREEM or the RCS.
Old May 28, 2015 | 11:16 PM
Cedar11's Avatar
Thanks for your response. What is the RCS?
Old May 29, 2015 | 08:56 AM
Suddenly dies completely, but restarts OK means an intermittent somewhere in the ignition or fuel injection.
I'd try sending the RCM ( K40 ) to tighed1 and include a note requesting he replace the fuel relay ( along with $25 ).
Other than that, if it is ignition related, then you seem to have covered the 2 CPS ( crank and cam ).
This leaves circuitry, ECM, SKREEM. ( no fun there at all ).
Could try cleaning the Crank sensor connector real good.
Old May 29, 2015 | 09:01 AM
tighed1's Avatar
Thanks fer da plug.
You can contact me at
tighed1@hotmail.com
for the details. (XF mailbox is full)
Old May 29, 2015 | 03:31 PM
Let me tell you this, the RCM module is a source for many issues exactly like you indicate. Please be sure to understand this repair is offered as a benefit to many members past. It has saved way too many members hundreds if not thousands of dollars in costs associated with this type of issue. The offer suggested by seasoned members of this forum are in no way meant to steer you into something misleading. I trust these guys offering the solution, you should too. If by chance this does not correct this issue, you can rest assure it will be the most least expensive attempt at repair you will ever find, anywhere. Send the RCM in for inspection/repair. The peace of mind is priceless. If you don't believe it, just spend a few days perusing the forum with a few keyword searches relating to your issue. No guarantees except the record of successful solutions posted herein, for issues like this. Good luck!
Old May 29, 2015 | 08:50 PM
Cedar11's Avatar
Thanks for the advice guys, I have contacted tighed1 and I hope that this will fix the issue!
mhajek18
Dec 30, 2015 03:40 PM
BEATv1
Jul 16, 2015 09:40 AM
livefreeordie
Jul 3, 2015 03:32 PM
autumnmass
Jul 2, 2015 10:35 PM
blackpepper
16
Jun 2, 2015 12:50 PM
