Car not running - Fix it or sell it?
Old Jul 6, 2015 | 08:34 PM
gtjl's Avatar
Default Car not running - Fix it or sell it?
Over a month a go I had this problem:
https://www.crossfireforum.org/forum...k-tumbler.html
I took it to a local shop thinking that the problem was simply the push-start aftermarket button without really troubleshooting the car. The guy had my car for over a month and did nothing besides pulling and tearing apart all the push-start button system, he lost the key that was wired to the push start button. i towed (again) to one of the best shops in Philly and they have told me that I will need to get the original ignition switch and install so I could take to the dealership an reprogram the computer to match the code of the spare key.
I am trying to decide what to do. I have towed the car three times (+$500) the new part will be at least another $500 and I don't know if after all the problem with the car was the push-start system.
The car has 125,000 miles on it.
I am trying to decide if it will be worth to fix it and keep it/sell it or sell it like in its current status.
Old Jul 7, 2015 | 06:44 AM
Default Re: Car not running - Fix it or sell it?
Have you thought maybe about contacting all the breaker yards on car-part.com and asking if they perhaps had a car with a matching ignition key assembly, key fob and skreem ?
( look up the yards by searching on ignition switch )
Here's the search for just the southeast :
Old Jul 7, 2015 | 07:23 AM
gtjl's Avatar
yeah I did. what else do I need besides the ignition switch and key?
Old Jul 7, 2015 | 07:39 AM
The RFID chip in the key must match the skreem
Old Jul 7, 2015 | 11:10 AM
Mrmiata's Avatar
If you actually have an "OEM spare key".. why deal with a skreem and mess? It's RFID chip is already programmed for the car.. (even if you were told to "have it programmed"... that's just BS) The metal key and switch is what you need to get away from the push start thing..
Old Jul 8, 2015 | 07:39 AM
gtjl's Avatar
The guy said that the code in the spare key doesn't match the one in the sckreem
Old Jul 8, 2015 | 10:24 PM
KDW4Him's Avatar
How would he know that? If this were the original OEM key it has to be the correct chip.
Old Jul 8, 2015 | 10:28 PM
Mrmiata's Avatar
I guess cause it wouldn't start..
Even with the chip missing or "wrong" when other issue is fixed.. it should act just like a skreem failure.. two or three attempted fires to life and die.. then disconnect battery and same cycle..
Old Jul 8, 2015 | 10:39 PM
AH, another nightmare with an aftermarket, Chinese keyless start.
See why I warn and warn and warn people about those damn things? You take a car already hard enough to diagnose and then add some cheap consumer-grade piece of **** to it and what do you get?
No, not here offering any advice, that is covered - I am simply posting for OTHERS to READ and LEARN.
Old Jul 8, 2015 | 10:40 PM
2nd this most experienced advice for those willing to listen!
Old Jul 9, 2015 | 08:56 AM
KDW4Him's Avatar
I missed something then. If this was working at one time all of the chips had to be good. I don't understand how in the middle of diagnosing it you decide the RFID chip is incorrect. And if that is the case then a new FOB from needswings would solve this regardless of pushbutton start.
Double ditto what pizza guy said!
Old Jul 9, 2015 | 11:15 AM
Mrmiata's Avatar
It's those little details you have to pay attention to ..
Old Jul 9, 2015 | 12:10 PM
KDW4Him's Avatar
So a Needswings FOB would fix this.
Old Jul 9, 2015 | 12:16 PM
Mrmiata's Avatar
Well it would get you the chip matched to the vin.. but it does raise the question of "is the skreem original".. that could open a whole new can of worms... and I only mention this to go along with "spare doesn't work".. Not an expert on this but do know if dealer repairing a system doesn't get the "code" pulled from the old one.. you get to buy new keys to go with it all.
Old Jul 9, 2015 | 07:10 PM
arejohn's Avatar
did the spare key ever start the engine?
Old Jul 12, 2015 | 04:51 PM
gtjl's Avatar
I have never used that key because when I bought the car it came with the aftermarket push/start button.
Old Jul 12, 2015 | 05:20 PM
Mrmiata's Avatar
Even without the transponder chip.. when the problem is resolved of the "start button".. (have you checked the RCM? link in my signature) the car starter should work.. and the car "should" fire to life for a brief second then die. 3 of those near starts (some claim 2) and you have to pull the battery cable to try again.. but do not do this repeatedly as legend has it after 30 attempts and fails it self destructs.
So once you get it "trying" to fire.. move the spare key-transponder into the proximity (on top of) the transponder ring to see if it will fire and run.
Old Jul 22, 2015 | 06:28 PM
Toolman's Avatar
I don't believe the OP has the car anymore. Early last week I saw a local Craigslist listing for a Crossfire with the push to start problem that "just needed a key assembly" for $1,800. The listing was only up for a few days.
autumnmass
Jul 2, 2015 10:35 PM
ultrajim49
17
Jun 27, 2015 12:20 AM
Meanberg
Jun 14, 2015 02:25 PM
lorie
Jun 9, 2015 10:08 AM
adamlevy
Jun 7, 2015 08:13 PM
