Fuel pump question
Old Aug 15, 2015 | 11:32 AM
umpqua rafter's Avatar
Default Fuel pump question
Hey everyone,
2004 Crossfire. Should the fuel pump hum when the key is on? Mine doesn't. The car will run about a minute, then quits. I've already replaced the ECM, and the CPS. I'll replace the filter, but I'm not sure about checking the pump too.
thanks
Old Aug 15, 2015 | 01:10 PM
waldig's Avatar
Talking Re: Fuel pump question
THere is a pressure port on the fuel rail on the passenger side of the engine pointing toward the right front bumper corner , looks like a tire valve, I did lots of testing and you can monitor rail pressure there.
If the fuel pump is dead you can run on the 'vacuum' in the motor pulling fuel thru the pintel of the injector but as soon as you touch the throttle, it stalls.
Enjoy Wdy
Old Dec 16, 2020 | 08:13 PM
far103's Avatar
Default Re: Fuel pump question
check the relay module thats the problem
Old Dec 16, 2020 | 09:10 PM
It's been five years, don't ya think he's fixed it by now?
Interesting point that Woody made. I"m gonna try that.
Jefwder
Oct 28, 2018 06:58 PM
edcrossfire
Apr 16, 2018 10:55 AM
kolevski
Oct 5, 2010 12:17 AM
tunaglove
Jun 1, 2010 08:37 AM
ohnoesaz
Jan 20, 2009 12:56 PM
