Musshy brake pedal
Old Apr 7, 2016 | 09:39 AM
kstewart's Avatar
Default Musshy brake pedal
I have found the only cure for a musshy brake peddle is to flush the brake fluid with new. What make the problem is sitting for long time, not being used. The BAS light will come on also when this problem happens.
Old Apr 7, 2016 | 11:44 AM
4drturbo's Avatar
Default Re: Musshy brake peddle
Drive the car more. Have the fluid flushed every 2 years with ATE Typ 200 brake DOT 4 fluid. Just 1 can is needed. They run around $20 on eBay.
Old Apr 7, 2016 | 02:32 PM
JEFASOLD's Avatar
If you bleed the brakes when it is really cold, you'll find that they won't get mushy in the warm weather.
glover
Dec 28, 2022 04:08 PM
ashkanmo
Apr 27, 2016 02:31 PM
IsaacF
Apr 12, 2016 03:14 PM
Mark SRT6
Apr 8, 2016 09:58 PM
EbonyXF
Apr 7, 2016 06:12 AM
