Spoiler deploy no start 2004 crossfire help
Old Jul 30, 2020 | 07:29 PM
Default Re: Spoiler deploy no start 2004 crossfire help
This photo is obsolete and has been replaced.
Dave, That looks like the updated photo to me.
You SURE?
Old Jul 30, 2020 | 07:36 PM
Originally Posted by bc75
It just started again but the spoiler will not go down. My ABS BAS and ESP lights are on and it wont come out of park. .
When the car starts number 2 relay closes when it doesn't the relay stays open.But the lights on the dash stays on and will not go in gear.
Yea, if #2 is the Traction control relay - then your trouble is that relay opening. If the Traction control relay is not closed, you CANNOT shift from park by design. Also, the Antilock Brake Controller and Transmission control module are not powered up if that relay is not closed.
But Dave thinks the photo of the relays is the wrong one -and I cant remember the difference between the RIGHT one and WRONG one. SO we gotta wait for him to tell us.
Old Jul 30, 2020 | 11:25 PM
bc75's Avatar
I have tried to soldering the RCM but still wont start and spoiler still up.
Old Jul 31, 2020 | 03:30 AM
tighed1's Avatar
If resoldering the 3 bad joints didn't work, the relay itself is going bad. I can replace it for you. Email me at tighed1@hotmail.com for the details.
Old Jul 31, 2020 | 03:24 PM
bc75's Avatar
Would that cause the spoiler to go up and not to go out of park? I knew it would make it not start.
Old Jul 31, 2020 | 07:35 PM
tighed1's Avatar
A bad traction relay can cause a bunch of different issues. No gear selector indicator. Won't shift. Wing up. BAS/ESP fault. Speedometer inoperative and others.
You may get one or multiple faults.
Old Aug 3, 2020 | 11:05 PM
bc75's Avatar
I ordered a new RCM. I put it on today runs better than it ever has. Thanks for the help im going to send the old one to be repaired so ill have a spare.
Old Aug 9, 2020 | 07:21 PM
bc75's Avatar
Well it won't start again. Key fob doesn't work and will start and die 3 times then nothing. I tried to disconnect the battery it didn't work. Im afraid its my skreem. The only code im getting is p2071
Old Aug 10, 2020 | 06:00 PM
Are you sure about a SKREEM issue ( I tried to disconnect the battery it didn't work. )? If SKREEM, it'll repeat the 3 times then nothing, and when battery disconnected it'll repeat the same.... Help us help you...
Old Aug 10, 2020 | 11:42 PM
bc75's Avatar
It will start and die 2 times. The 3rd time nothing. I disconnected the battery . The same thing.
Old Aug 10, 2020 | 11:53 PM
THAT is the classic SKREEM failure symptoms, you can search that on this forum and get 100's of hits, it all boils down to contact SOS Diagnostics.
http://www.sosdiagnostics.com/crossfire.html
Old Aug 11, 2020 | 01:17 PM
Classic SKREEM!
S.O.S. Diagnostics
Second George's post, classic SKREEM.
When enough information is given the membership can steer you best! Sounds like your having a bunch of issues one right after the other! Good luck!
Old Aug 11, 2020 | 01:21 PM
bc75's Avatar
Well i wanted a project. I got one. 😀
Old Aug 29, 2020 | 05:01 PM
bc75's Avatar
Got my ECU back from Precision ECU today. Car runs again.
