High rpm idle
Old Jul 27, 2017 | 04:22 PM
IamNIkoSuave's Avatar
Default Re: High rpm idle
Originally Posted by Padgett
Video sure looks like the butterfly is sticking open. Have you tried opening the hood and closing by hand ? (is it reachable ?)
isnt the throttle also electronic?
Old Jul 27, 2017 | 05:30 PM
Padgett's Avatar
Throttle being electronic means there is a servo opening the butterfly. Butterfly can still not close all the way when warm.
Just cannot close it by pulling on the pedal. Could tell very quickly with a scan tool or my cell phone since one of the OBD-II parameters is throttle (butterfly) position.
Old Jul 30, 2017 | 09:57 AM
Just finished replacing the throttle body with a 74 mm...letting the motor learn the new throttle body first before seeing if the issue is still there
Old Jul 30, 2017 | 10:00 AM
Originally Posted by iamnikosuave
just finished replacing the throttle body with a 74 mm...letting the motor learn the new throttle body first before seeing if the issue is still there
still does it...i don't know what else to do...getting really discouraged about my car right now
Old Jul 30, 2017 | 12:15 PM
UK Sid's Avatar
Have you tried doing a throttle body reset?
Also, it could be the throttle position sensor starting to fail.
Old Jul 30, 2017 | 12:48 PM
I did do the throttle reset. If I'm not mistaken we dont have a throttle position sensor, but you're talking about the accelerator pedal sensor?
Old Jul 30, 2017 | 01:13 PM
The only thing my OBD scanner is showing
UK Sid's Avatar
Yes, I meant the gas / accelerator pedal position sensor.
When these start to fail they can give odd symptoms.
Old Jul 30, 2017 | 01:27 PM
even if it only happens on a warm start?
Old Jul 30, 2017 | 02:23 PM
UK Sid's Avatar
I believe so.
All you can do is narrow it down.
AFAIK, the throttle position sensor sends a signal to the ecu. The ecu interprets this signal, in turn operating the throttle body. You've already replaced the throttle body, and mis-interpretation of the signal by the ecu is reasonably unlikely - leaving the tps?
Old Jul 30, 2017 | 02:50 PM
I believe so.
The TPS IS the throttle body ! It is a resistive strip on a circuit board inside the black cover.
Old Jul 30, 2017 | 03:06 PM
UK Sid's Avatar
TPS is the throttle position sensor. Throttle body is the throttle body.
https://www.ecstuning.com/b-genuine-...ly/1703000104/
Old Jul 30, 2017 | 03:09 PM
That is the Throttle PEDAL Assembly, I repeat, the TPS is integral to the throttle body :
Old Jul 30, 2017 | 03:15 PM
So if it is the pedal, are all the pedals the same? I have an 05 base with a 6spd. Part number?
Old Jul 30, 2017 | 03:20 PM
UK Sid's Avatar
Apologies xfire,
Over the pond we often call the accelerator the throttle.
I'm referring to the sensor in the accelerator pedal, which we would often call the tps.
Old Jul 30, 2017 | 03:41 PM
UK Sid's Avatar
It's in the link in post #32 buddy.
I think they are the same.
Old Jul 30, 2017 | 04:50 PM
Padgett's Avatar
Well I'd start here with a shot of normal idle and another of high idle. (Torque Pro on Android)
Old Jul 30, 2017 | 06:53 PM
  #38 (permalink)
https://www.youtube.com/watch?v=abHDRl8miRo
Huh? ...........
The only Bowden cable under my NA hood was for the hood latch.
Old Jul 31, 2017 | 02:20 PM
  #39 (permalink)
bought a used one off a guy in the fb group and hopefully it works.
Old Jul 31, 2017 | 05:34 PM
  #40 (permalink)
UK Sid's Avatar
Huh? ...........
Yeh,
That's an older set-up - I didn't check properly..........
