High rpm idle
Old Jul 31, 2017 | 05:35 PM
  #41 (permalink)
UK Sid's Avatar
Default Re: High rpm idle
Originally Posted by IamNIkoSuave
bought a used one off a guy in the fb group and hopefully it works.
Let us know how it goes buddy..
Old Aug 3, 2017 | 08:18 PM
  #42 (permalink)
IamNIkoSuave's Avatar
have the replacement pedal...but that damn washer is a pain to remove. Been at this all day just trying to get that washer out. Using magnets and pick tools to no avail 😡😡😡😡
Old Aug 13, 2017 | 04:31 PM
  #43 (permalink)
Pedal is replaced. Issue is gone!!! Kinda...I can do a warm start, itll hold still...but I turn the ac on and it goes away. Any thoughts?
Old Aug 14, 2017 | 09:32 AM
  #44 (permalink)
waldig's Avatar
Talking Re: High rpm idle
Have you checked vac leaks? Engine feeds fuel to air provided, a leak is like throttle being open a bit more. Listen for leaks --check hoses. Woody
Old Aug 14, 2017 | 02:08 PM
  #45 (permalink)
This would have been my first choice (vac leak), hope you can nail this down! Good luck.
Old Aug 14, 2017 | 02:39 PM
  #46 (permalink)
Vacuum leaks were the first thing I checked and couldn't find any
Old Aug 14, 2017 | 03:08 PM
  #47 (permalink)
liljay's Avatar
Might be a stupid question, but I have to ask. Throttle Reset? If not your vacuum leak may be the throttle oRing.
Old Aug 14, 2017 | 05:05 PM
  #48 (permalink)
Steve Jr's Avatar
Are you asking what a throttle reset is?
Old Aug 14, 2017 | 06:00 PM
  #49 (permalink)
liljay's Avatar
Nope, thanks for checking. I perform the reset everytime I wipe the P0410. I didn't follow all the previous threads and someone had already checked to see if he had performed the reset. He never mentioned the Oring when upgraded the throttle body.
Old Aug 14, 2017 | 06:34 PM
  #50 (permalink)
O ring was replaced and performed throttle body reset
Old Sep 3, 2017 | 04:20 PM
  #51 (permalink)
UK Sid's Avatar
Any updates on this?
Old Sep 3, 2017 | 06:57 PM
  #52 (permalink)
replaced the gas pedal and she's fine!
oh and an automatic transmission pedal works just well in a manual transmission pedal. Just have to remove the wide open throttle sensor and put that dummy block in.
Old Sep 4, 2017 | 02:44 PM
  #53 (permalink)
UK Sid's Avatar
Nice one - glad it worked out for you..
