Dead Battery
Old Oct 23, 2018 | 02:56 PM
Default Re: Dead Battery
I believe there is also an issue where the batteries corrode and destroy the circut board inside causing a battery draining short. Do a search on sirens.
Old Oct 23, 2018 | 03:41 PM
Hindin's Avatar
You are correct. The corrosion from the failed batteries have caused havoc with the circuit board in the siren module. My question more specifically was prior to total failure and acid leakage from the batteries, are they being recharged and what effect might failing/old NI-MH batteries have on car battery drain. My experience with NI-MH batteries is that as the battery ages, its ability to hold a charge decreases which results in more frequent recharging.
Old Oct 23, 2018 | 03:50 PM
I have no recollection of these batteries draining the car battery. They leak when they are at the end of their life and the electrolyte inside finally eats through to the outside. I presume that they are self regulating with regard to charging, maybe that accounts for the extensive circuit board inside them. They do not trickle charge very easily if at all.
lumpdog
Jan 28, 2017 11:10 PM
ProjectMayhem
Jul 14, 2008 07:16 PM
ben47
May 5, 2007 10:08 AM
srtwindsor
Apr 13, 2007 04:06 PM
al_luss
Aug 24, 2006 02:04 PM
