car won't start and key will not come out of switch
Gentlemen - Have a 05 Limited Coupe and another electrical problem. Yesterday the car started and ran fine. Washed the care and opened the doors to check that water was draining OK from door bottom. Took a small stiff wire and poked the drain holes to be sure. When doing the drivers door, the alarm went off. Finally got that stopped. but the lights were flashing. Started the car to pull it back into the garage. Everything still OK. Today. I backed it outside to apply tire dressing. Went to pull it back in and it won't start and the ignition key will not come out of the ignition switch. The key turns to the start position, but nothing happens. When turning it back to remove it, it turns back to that position but will not come out of the switch.
Any ideas or suggestions will be appreciated. I've search, as best as I could, on the forum but can't find a similar problem. Plenty about sticky switch's but not like I have. I'm suspecting it's something to do with the alarm system since that went off yesterday.
Again, any ideas or possible solutions will be appreciated.
Thanks,
Jim
jpmlholian@aol.com
Thanks,
Jim
jpmlholian@aol.com
Thanks,
Jim
jpmlholian@aol.com
Thanks,
Jim
jpmlholian@aol.com
180 - You got me to thinking. So I went out and checked and the gear shift lever was in park. For the heck of it, I moved it all the way down to drive and then back to park. WALLA - now everything works as it should. I can't explain that one. Maybe I didn't have it all the way into park, but I thought I did. Or else it's some other little gremlin that I hope does not come back again.
Thanks for getting me thinking. It worked, I think!
Jim
Jim
More likely there is enough play in the linkage not to have gone all the way into Park..Key can only be removed in Park so was a clue.
Thanks Guy's. Thank goodness I learn something new everyday, particularly on this great website.
Jim
Jim
No cable onehundred but there is a bushing on the linkage where it connects to the transmission, and it should be replaced every 50 to 75000 miles . Mattmiami has them and he will be at the dragon.
Gentlemen - Thanks again. This is something I will keep in my hard copy files for the Crossfire.
Jim
Jim
this cable is (on auto only) it is to ,,when you push the brake ,it releases the shifter so you can get the tranny out of park, it also lets the key turn,,, it has nothing to do with no going fully into park, so you can remove your key .
Everyone else can make up their mind on whether you can push the brake pedal on autos and take the tranny out of park, you cannot.
You have to hit the hidden switch under the shifter cover to do that.
The cable is the only connection between the tranny shifter and the ignition switch.
You cannot remove the key until the shifter is in PARK and the key is in the OFF position.
They key turns a little past the ACC position and goes the rest of the way to OFF when the shifter gets into Park.
The cable is called the Ignition Lock Cable strangely enough.
If this cable was somehow not to spec or the mechanisms at either end faulty I could foresee problems with the key removal.
You are right and I am right, in our shop J S Benz and matt's shop we have had over 100 mercedes with 4 of those being crossfire's (key would not remove when in park) , replaced the bushing on the linkage,,,fixed.
quote: you can push the brake pedal on autos and take the tranny out of park, you cannot. end quote:
when key is in on position you can and only then so yes the cable does release the shifter,, a worn out bushing will (sometimes ) not let the transmission be in the gear showing on the dash , so we are both right.
This thread is about not having the key in the ON, but about getting the key out, and it will only come out in P.
The key has to be turned to the ON position to move the shifter and the cable allows that. It does not allow it to occur in the ACC position.
Both points are right but only one case is relevant on this occasion.
RoadsterBabe
Jan 31, 2022 05:14 PM
MXQB7
Jul 11, 2013 10:56 PM
blkXfire04
Jan 23, 2013 07:56 PM
