Throttle sticking?
I have a 2004 crossfire base manual and when I reach about 30 mph the rpms go up to redline while driving. The only way I can get it to go down is to shut the car off while I'm costing with the clutch in. It only does this when I reach 30 miles an hour. Any reason this might happen? I tried the throttle reset procedure a couple times but to no avail. The car sat for a couple of weeks in the winter and this problem happened after I started driving it again.
It starts after I put it in 3rd. But even when it's in gear the car is still accelerating with no input on the gas. After I press the clutch in it then goes to redline and I have to shut the car off.
This sounds a bit like what I have experienced. But I think you should re-write your post. Is the engine going to that RPM with clutch in?
So try to describe EXACTLY what is going on and what gear you are in, etc.
I have had two 6 speed Crossfires that will open their throttle on their own, has nothing to do with the pedal - but in my experience, it only happens exactly like this:
Is THAT what is going on? If not, DESCRIBE EXACTLY what is it doing like I did.
I think I figured my issue out. Tell me/us what your car is doing and I'll expand on what I[m talking about.
EDIT: As I read your post, I am sure we are talking about the same issue. FINALLY someone else is having the same trouble!
- I've driven the car for some time, it is well warmed up.
- I stop for 2-10 minutes.
- I start it up and immediately go DOWN HILL from where I had stopped.
- I notice the car seems to be speeding up, the throttle is opening, tho I am trying to coast.
- I push clutch in, and the tach goes to around 4300.
- The ONLY way to stop this is turn the key off, then back on - it may be ok, may do it again.
- Once I get to level ground, there is no issue, it is the downgrade that is causing it.
progress
26
May 15, 2011 01:15 PM
progress
Apr 7, 2010 09:24 PM
HellsAngel91
Aug 27, 2008 04:16 PM
gtashe
Aug 23, 2004 08:14 PM
lmf101
Jun 11, 2004 12:45 AM
