05 crossfire will crank all the time but wont start I was testing for a parasitic dr
Old May 5, 2019 | 11:49 PM
Oldman67's Avatar
Default 05 crossfire will crank all the time but wont start I was testing for a parasitic dr
Hello I was trying to track down a parasitic drain on my 05 Chrysler crossfire I found that if I pulled fuses numbers 9 and 35 the drain would stop I put the negative cable back on and tried it without the 2 fuses and the car wouldn't even turn over so I put the fuses back in and now the car will crank as many times as you want but will not start now wont even try to start like a stumble it just cranks and cranks and cranks until the battery is dead I figured I have triggered Something in the anti theft system please help and thank you
Old May 6, 2019 | 09:02 AM
Default Re: 05 crossfire will crank all the time but wont start I was testing for a parasiti
replace the RCM
Old May 6, 2019 | 12:38 PM
ttmmdd's Avatar
Hve you checked to see if you have fuel pressure?
Old May 6, 2019 | 11:36 PM
lovecross's Avatar
Originally Posted by amx1397
replace the RCM
And the crankshaft position sensor (Bosch) for good measure. Avoid dealer parts dept.! (RCM often called Computer Control Relay by online parts sellers).
ddonner
21
Jun 5, 2023 01:21 PM
texasboy_11b
Oct 13, 2022 08:05 PM
Missfire
Sep 28, 2013 10:04 PM
jpeez20
Sep 10, 2011 11:19 AM
