check engine light on - P0335 Crank sensor
Old Jun 18, 2019 | 10:01 PM
PSD's Avatar
PSD
Default check engine light on - P0335 Crank sensor
Strange day today, drove the Crossfire about 20 miles round trip, couple of short stops, some traffic, got it nice and warmed up.
Went home, car sat for somewhere between 1-2 hours and then wouldn't restart. Cranks like crazy but not even trying to start. The fuel gauge was on E but above the red zone. Seems like there was fuel but just to be sure I drive another car to the station, get gas in a jerry can, drive home and add about 4 gallons. Turn the key and it fires right up. At this point I notice the check engine light and read the crank sensor code..
So, did the motor heat-soak the crank sensor and then cool off enough when i went for gas? or is my fuel gauge possibly reading too high and I actually was empty? In hindsight I should have tried to start the car again when I got back home from getting gas(before adding any).
I will try to replicate the drive cycle tomorrow and create a crank/no start again. this time will cool the crank sensor with compressed air and see if it will start.
Old Jul 13, 2019 | 12:10 PM
PSD's Avatar
PSD
Default Re: check engine light on- P0335 Crank sensor
problem was heat soak. new sensor solved it.
Old Jul 13, 2019 | 12:27 PM
JSK's Avatar
JSK
Thanks for coming back with the fix.
ddonner
21
Jun 5, 2023 01:21 PM
xfireon20z
Jul 20, 2015 04:35 PM
MikeR
Apr 30, 2013 09:12 AM
mhoward0058
Feb 6, 2012 07:42 PM
Iseron
New England Forum
May 27, 2008 08:59 AM
