B10F5-Speed Sensor Status Signal Invalid
Old Jul 14, 2019 | 11:05 AM
srbaker's Avatar
Default B10F5-Speed Sensor Status Signal Invalid
My ABS/ESP lights are currently on. I took the vehicle to the dealer where they performed a number of checks, supposedly cleared the codes and could find no faults. When I got into my car the lights were back on the dash (also my hood wasn't latched, good thing I noticed before going too far)
When I went back in they indicated if I left the car with them they would eventually find the problem. At $109.00 per hour it could be an expensive endeavor (I may not have a choice).
I was wondering if anyone has experienced this particular code?
The possible causes are Wheel Speed Sensor Status Signal Circuit open (not found to be open)
Controller Antilock Brake (CAB) No indication it is faulty
Occupant Restraint Control Module (ORC) No comment made
Two events preceded the lights coming on which I conveyed to them. I had washed the vehicle with a power washer and shortly thereafter had to make an extremely quick stop due to a truck turning in front of me. It was within a few minutes that the lights on the dash illuminated.
Any feedback would be appreciated. I did see the Tech use an aftermarket OBDII to clear the codes. Is it possible due to the Chrysler/Mercedes hybrid nature of the Crossfire that his reader could not properly clear the code hence its return? This particular dealer has never sold a Crossfire and has only serviced one Crossfire in its recent history.
Mad_Med05X
Apr 14, 2021 10:10 PM
Mdcrossfire
Feb 19, 2019 08:13 AM
TonySan
Jul 26, 2013 01:32 PM
DICKBEE7631
Jan 20, 2010 12:08 PM
BRappaport
May 20, 2007 10:32 PM
