Alarm Issues and Locking Issues
Old Jun 22, 2019 | 06:19 PM
hemifiedbird's Avatar
Default Alarm Issues and Locking Issues
Our 05 Vert was in the garage with key in the ignition, No one was near the car for a month, Went to move it and the doors were locked, key inside. Towing lock button flashing on console. Had to break into car as cannot find second key. Got into car and alarm was screaming lights flashing. Hit remote and it would not clear. Killed the power on the master switch and put in new batteries in remote. Still will not lock or unlock car. Lights flash but alarm does not go off as i have pulled the fuse on #9. Hooked a scanner to the car and it has a panic button on remote shorted code. Cleared the code and the car is the same. The Towing lock button is still flashing. The car will start but shuts off right away so the alarm must still be activated somehow. Anyone have this happen or any ideas what to try next. Battery is 3 months old and load tested, it is fine. Cables clean. Thanks
Old Jun 22, 2019 | 09:54 PM
Default Re: Alarm Issues and Locking Issues
I assume you disconnected the battery cables and let the system clear. Wait about two minutes before reconnection.
Word to the wise, Do not leave the key in the ignition. I believe it becomes active.
I do not know if this works but it is the fist thing I would try on just about any electrical issues with the engine management or security system.
Old Jun 22, 2019 | 10:54 PM
Yes i removed the cables and let it sit overnite, Still the same. Weird thing is the towing lock light continues to flash, and following instructions to cancel it does not work. If I pull # 9 fuse tha alarm does not sound but the lights all flash
Old Jun 22, 2019 | 11:34 PM
ttmmdd's Avatar
You might try resyning your fob
Old Jun 23, 2019 | 12:12 AM
ttmmdd's Avatar
Thanks Ragand! I experienced many of the same problem as others here ... car was fine but then key wouldn’t work (except manually), dash lights on but car wouldn’t start. Had the battery checked, it was good. Ran to the store and bought new batteries for key, that didn’t work. The button for the tow lock kept flashing and couldn’t be turned off. Took your advice and removed the battery cables, then touched the cables together for 15 seconds with the assist of a wrench. Reattached battery cables, Turned the ignition and wahoo! All was working as before
Old Jun 23, 2019 | 09:32 AM
It should be made clear that the batteries in the fob and synchronizing the fob has nothing to do with starting the car, just opening the locks.
Old Jun 23, 2019 | 09:47 AM
ttmmdd's Avatar
By resyning the fob, I was thinking more along the line of trying to clear the alarm state the car seems to be stuck in.
Old Jun 23, 2019 | 11:00 AM
I should note that the remote does nothing for unlocking or locking the doors, Holding both buttons I do get a red light come on and individual buttons i get a red light come on but the car is not responding, How do you re sync the remote?
Old Jun 23, 2019 | 11:44 AM
ttmmdd's Avatar
1. Press either the lock or unlock button momentarily twice.
2. Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Old Jun 23, 2019 | 12:06 PM
The red light is just to show the batteries are OK, these fobs operate on radio frequencies, not infra red. So a clear line of sight is not requied.
Old Jun 23, 2019 | 10:54 PM
Did the press button twice and key turned on and no change, lights and dash lights flash and towing switch flashes red
Old Jun 23, 2019 | 11:35 PM
ttmmdd's Avatar
Did you try disconnecting the battery and shorting the cables together?
Old Jun 24, 2019 | 02:56 PM
Yes, made no difference. I am getting a code of a shorted panic button on my scanner. I am going to try a different remote but I am feeling it is probably a module screwed up or shorted
Old Jul 15, 2019 | 01:24 AM
I am still trying to figure this car out. I ordered a new key and it is not in yet. Doing some checking and find that the doors and trunk will lock with the button on the dash but will do nothing with the fob, Also noticed that the fuel door will not unlock but everything else does but only with the switch. I pulled #9 fuse and the alarm does not sound but all the lights flash and the tow button continually flashes. The car will start momentarily and quit with all lights flashing.Any other ideas that anyone has run into would be appreciated
Old Jul 21, 2019 | 02:52 PM
lovecross's Avatar
Post Re: Alarm Issues and Locking Issues
Skreem module? Water damaged locking control pump in "basement" of trunk? Just thoughts from a non-expert...good luck with it.
Old Jul 22, 2019 | 02:09 AM
Removed the locking pump and circuit board today, Visually there is nothing appears wrong but when i unplugged the one wire my alarm issues went away (flashing lights ,siren) plugged it back in and everything started again. Any one know how to bench test this unit? Tried starting the car with it unplugged and it started but it started but shut down. Tested locking pump with scanner before removal and there were no codes. Do have a code for the skreem module but i don't want to just throw parts at it before I am sure
Old Jul 22, 2019 | 10:24 AM
The service manual has a section on the vehicle security, it has instructions on testing the unit. The 2004 manual is the easiest to read.
Larry Hitze
Feb 5, 2019 12:57 PM
JereRB
Jul 6, 2017 05:09 PM
bhindzioncurtain
39
Jun 3, 2017 11:22 AM
modernuser
Sep 2, 2015 01:13 AM
GraphiteGhost
Nov 27, 2010 09:40 AM
