engine quits
Old Oct 8, 2019 | 06:10 PM
canman80's Avatar
Question engine quits
We have a 2007 Aero Blue roadster (original owners) 55K miles.
The engine quit today just after leaving the house. Finally restarted and limped it back home in fear of engine dying on the road.
My neighbor scanned it and did not get any codes. I have heard of this before but first time happening to me.
Where do I start looking?
Old Oct 8, 2019 | 06:36 PM
Default Re: engine quits
More symptoms. How fast were you going when it died, did it immediately restart, did it go into limp mode, were there any other odd behaviors or sounds etc.?
Old Oct 9, 2019 | 06:50 AM
canman80's Avatar
low speed, like 5mph, engine takes several attempts before restarting, possible clicking noises too from starter, someone outside the car said they heard it.
Old Oct 9, 2019 | 05:31 PM
tighed1's Avatar
I'd say three possibilities.
1. Battery.
2. Crankshaft Position Sensor. It will generally throw a fault code. Replace ONLY with BOSCH CPS.
3. Relay Control Module. Check out the "RCM Repair" link in my signature.
Any other symptoms?
Wing stays up?
Radiator fan spins up REALLY fast with the key in the ON position?
Can you hear the fuel pump run for 2 seconds when you first turn the key to the ON position?
Old Oct 17, 2019 | 08:23 PM
canman80's Avatar
1. Battery.
Any other symptoms?
Wing stays up?
Replaced the RCM relay and cured all the engine issues, thanks for the help.
r
Old Oct 17, 2019 | 10:07 PM
tighed1's Avatar
Say what! I couda saved you sum buckz!
I repair rcm's.
Send me yer old one and I'll refurbish it and make it better than the one you bought!
Email me at tighed1@hotmail.com for details!
Old Oct 20, 2019 | 03:43 PM
canman80's Avatar
Really? I had a guy try to solder it. You think you can save it?
Old Oct 20, 2019 | 04:33 PM
He will not only save it but make it better, as he said. It is better to have a spare anyway.
Old Nov 20, 2019 | 09:46 PM
Towncrier's Avatar
Was nearly stranded with my 15 month old today when my 2006 exhibited some of the symptoms attributed to a faulty RCM. It seemed like the engine wasn't getting enough fuel. I have a lifetime Chrysler warranty, so I tried calling them for roadside assistance. The call center (obviously overseas) was no help. Funny thing is that they were so helpful when my CPS went bad a couple of years ago. After getting the runaround for 15 minutes, I tried starting the car and the engine started and ran just fine. I hung up on Chrysler (who, by the way, never called back) and drove home.
Temperature outside was around 70. I recently replaced the battery. I haven't tried scanning for codes yet. Does this sound like an RCM issue?
John
Old Nov 20, 2019 | 10:38 PM
zip439's Avatar
Towncrier, read posts 4 and 6 above.
Old Nov 21, 2019 | 09:59 AM
I repair rcm's.
there are a lot of new and old members here that don't know what you do, (most of our members know of me ,,i build race care,,well did for many years,, and i though i would repair my own RCM ,,and it worked for a day or two.. then i sent it to you tighed1 ,,you repaired it the way it should have been to start with. now with a spare or two with me at all times all done by you i drive without worry about my RCM
I'll put it this way people should not do their own surgery, give to someone that does it all the time,
thanks tighed1 for this great service. jim
Old Nov 21, 2019 | 10:06 AM
I second Jim's comments.
There for a spell several years back, DJ went walkabout and I tried replacing some relays for folks.
Not an easy job unless you have the proper tools ( which I do not )
I was happy to send him all my relays when he came back.
Old Nov 27, 2019 | 02:11 PM
mountainbmike's Avatar
Hi guys, on my 04coupe I added a bypass switch under the hood after my car started dying due to fuel loss. I ended up replacing the rcm but the bypass is staying in just in case ! The bypass sends power directly to the fuel pump wire. Only to be used to get home or trouble shoot the problem.
Mr.Troy
May 20, 2010 05:42 AM
GuyWagon
Jan 5, 2010 01:27 AM
satellite
Oct 28, 2008 06:24 PM
Kurts
Mar 21, 2008 01:51 PM
bflinn
Dec 30, 2007 10:14 AM
