transmission when cold
Old Dec 6, 2019 | 03:41 AM
ChrisA's Avatar
Default transmission when cold
My Transmission shifts real hard enough to jerk you in your seat but only when it is cold in the winter. I have had it to two independent shops and both said a fluid flush would help. any ideas of what this might be as it seems like something is going to brake soon.
Old Dec 6, 2019 | 10:01 PM
Default Re: transmission when cold
I have heard far too many transmission flush horror stories. Proceed at your own transmission's risk!
Old Dec 6, 2019 | 11:49 PM
I would start with the "old school" change fluid and filter. Obviously the fluid is at the correct level?
Old Dec 7, 2019 | 09:52 AM
zip439's Avatar
I would feel confident with a transmission filter change and complete flush from a Mercedes dealership. If you do not have the pressurized equipment and knowledge to DIY then it is wise to spend the money to have it done correctly. Our transmissions are an old and well understood item in the Mercedes stable; Getting the work accomplish there might be your best move. Cost is about $300 including the filter and fluid.
Old Dec 9, 2019 | 11:05 PM
ChrisA's Avatar
It has been flushed and the levels have been checked since. Still shifts hard enough to jerk you around hard.
Old Dec 10, 2019 | 01:29 AM
philosophico's Avatar
I have a srt-6 as well and mine does the same thing when cold until it is warmed up. I remember reading on here a few years ago that it was normal. Mine only does it on like 1-2 shift oddly enough. The other shift points are fine even when cold.
I will say my trans has over 200k now. I havent worried about it about it.
Old Dec 11, 2019 | 07:49 PM
ChrisA's Avatar
Thanks for the replies. My concern is that if taking off slow it will shift so hard that it just jerks you back and forth like a stick shift transmission
Old Dec 11, 2019 | 09:48 PM
Try running the Trans in "W" mode. I believe it starts out in 2nd instead of 1st.
TurboDan
Feb 15, 2011 02:46 AM
vladie22
Feb 25, 2005 10:19 AM
christo76
17
Jan 22, 2005 04:49 PM
XFiring
Oct 29, 2004 04:32 PM
english_bob
Jul 29, 2004 02:51 AM
