Indicators not working
Old Apr 17, 2021 | 12:13 PM
crossfire121's Avatar
Default Indicators not working
Hello all,
My left and right indicators do not work when I switch to indicate. The lights actually work as when I press the red hazard switch all 4 lights flash on and off.
Is there a relay / solenoid for the indicators or is the switch on the stalk ?
Thanks for your advice
Old Apr 17, 2021 | 01:27 PM
Default Re: Indicators not working
I think you have a bad "multifunction switch". If you can figure out the turn/hazard signal wiring, you are doing better than I am. Look at the wiring diagrams in the service manual, how would YOU figure out where the issue is? I can't find the damn flasher, I think it's a function of the BCM but Im' unsure.
You can gamble and just change the multifunction switch - seems to work for most of us.
Old Apr 18, 2021 | 06:12 AM
Thanks Pizzaguy,
It was a fuse ? The fuse was intact but by reseating the fuse it now works, prior to this the car had not been driven for a month so just a poor connection at the fuse.
Thanks for your help
Old Apr 18, 2021 | 09:56 AM
The clicking from the turn signal solenoid comes from the right of the steering wheel I cannot nail it down exactly. Some say it is on the rear of the instrument panel, I think not. It may be on the firewall, it is not in the emergency flasher as you would be able to feel it.
There are pictures of it on the web and it looks like the seat relay. It is not mentioned in any of my parts books, show in the Service Manual or in the booklet that shows where all the electrical items are located.
A total mystery to me, I remember Rudy fixing Tony’s flasher by straightening the contacts in his fuse panel in the car park of the hotel on a Woodward trip. I shall keep looking for this solenoid on the car though, getting under the dash is tough for me so maybe I will let someone else do it.🙂
Old Apr 25, 2021 | 11:33 AM
Hello Guys,
Well the problem is back with the indicator / multiswitch not working again , so it looks like I will have to get a new switch.
I saw on a " how to replace the turn / indicator switch " instructions on this site it mentioned the Mercedes R170 SLK part number as 170 540 01 44 but also another number 170 540 03 44 on the same thread.
Can someone please tell me which is the correct part number please ?
Thanks again.
Old Apr 25, 2021 | 11:34 AM
Forgot to mention I am from the UK
Old Apr 25, 2021 | 11:53 AM
Ronman's Avatar
Originally Posted by crossfire121
Hello Guys,
Thanks again.
The 01 44 number is for the shifter ****. The 03 44 has been superseded to 170540034464 and is the turn signal switch.
Old Apr 25, 2021 | 12:48 PM
Hello Ronman,
So the correct part number is Mercedes Benz 170540034464 for the turn switch or indicator as we say in the UK ?? I assume as my car is Righrt hand drive this part number will still be ok ? Big thanks again !!
Old Apr 25, 2021 | 01:22 PM
Hello Ronman,
Which side of the steering wheel does it go, ours is on the left.
Old Apr 25, 2021 | 01:25 PM
Ronman's Avatar
Hello Ronman,
Yes that is what I am seeing on a parts catalogue for the European SLK320 to confirm I would go to a Mercedes dealer website in the UK or call one. Select 2004 SLK320 and put in that part number and see if it matches or what comes up.
Old Apr 25, 2021 | 01:35 PM
Yes its on the left as well I did a quick google search for part No.170540034464 but cannot find anything .
Old May 2, 2021 | 12:22 PM
Hello,
I intend to replace the multi function indicator / turn switch.
I saw earlier on here that someone very kindly posted a how to replace the switch but I cannot seem to find that link.
Would someone please post that link again ? As I am having trouble removing the lower plastic part of the dashboard inorder to get to the plug and socket.
Regards
Tony
srt6-xfire
Jun 8, 2019 05:53 PM
billyjobling
Jun 9, 2014 12:38 PM
YraggarY
Feb 3, 2014 09:23 AM
Sonlil80
Mar 21, 2013 11:16 PM
kaiser
Jul 22, 2012 12:44 PM
