Back-up lights
Old Jul 19, 2012 | 04:56 PM
kaiser's Avatar
Default Back-up lights
Hi..I have a 2004 crossfire..6 spd manual..around 40k miles..Car runs great..When I took it for inspection earlier this year they said they could not get back-up lights to work..but passed it anyway...When I got home they seemed to work ok..Then and now either intermittant or not at all...Is there a switch that needs adjusting or something else that I need to replace? Please advise....Wayne..
Old Jul 19, 2012 | 06:58 PM
turbomar's Avatar
Default Re: Back-up lights
First thing I would check is the Back-up Switch located to the right of the output shaft, behind the flexdisc
Old Jul 20, 2012 | 08:11 PM
Mrmiata's Avatar
And what do we have here? Auto and Manual the same p/n ?
NEW MOPAR Back Up Lamp Switch P/N 5099770AA 2004-2008 Chrysler Crossfire | eBay
Old Jul 21, 2012 | 01:07 PM
turbomar's Avatar
That is the switch for the manual trany. I could be wrong but I think the back-up switch is integral part of the shifter assy. on the automatic
Old Jul 21, 2012 | 02:03 PM
Mrmiata's Avatar
Haven't a clue myself since I've never delved into the area, but I'd bet this ones cheaper than the stealer would offer.
Old Jul 21, 2012 | 04:35 PM
The manual says the auto reverse switch is an "integral" part of the shifter mechanism and cannot be repaired.
I've seen **** said like that before on part repairs and if you really care it can be done - sometimes.
I'd be looking for bad contacts somewhere before I decided it was the switch though.
Old Jul 21, 2012 | 05:25 PM
Mrmiata's Avatar
I agree.. but his is a manual so pretty much a non issue there.
Old Jul 21, 2012 | 05:52 PM
I know as I can read, I was agreeing with Turbo Mario through your post and adding a tip to the OP about seeking a cheaper solution as well, get it?
Old Jul 22, 2012 | 12:44 PM
turbomar's Avatar
When I performed the Paddle shifter mod, I had the whole shifter assy disassembles on the bench so, it can be serviced. Yes... Whenever I see the imfamous "can not be serviced" in a shop manual, it just gives me more determination to fix it myself anyways. I have also come to realize that: unservicable= expensive dealer item only
2004_
Jul 9, 2025 12:39 AM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
