new owner/Diagnostics scanner help
I have an autel ms906 that won't talk to my new used crossfire. Looking for recommendations on what to get that will. I spoke to a Mercedes dealer and he said good luck. if i try to manual get it he said to go in under the Mercedes slk171 not chrysler crossfire. I had better luck with the slk170. not sure what I should be trying or what scanner to get. currently waiting on needwings to rebuild my units.
Use the search box upper right corner and the google option. You will find several threads on the subject. There are several tools that will do most functions for about $200. I bought a Foxwell some time ago and it works well for me. Scan the car as a SLK 320 r170 if it is a Base or Limited, it will scan as a SLK 32 r170 if it is a SRT6. Roadsters are more of a problem as the hydraulics is different than the Mercedes.
