Battery drain
Old Feb 24, 2022 | 02:20 PM
sweeper's Avatar
Default Battery drain
Hello,
I have a battery drain problem.
I saved this 2004 base model car from weeds and I am very familar with almost everything cleaned couple hundred connectors. Been fine for couple years.
My Fluke on DC amps shows 9 amps not ma. Switch the leads and then I get 4 amps also not ma.
A brand new Optima wont last overnight and my original Optima was fine after getting it out of car.
This is quite a lot of drain cant do much in the middle of ice storm.
The difference in amps sounds like a diode.maybe alternator.
The chime is not working never did I will check to see if it is unhooked.
Any opinions would be welcome.
Down loaded Pizzaguys pdf funny guy
Thanks for any help the high readings might suggest someone can point where to look.
Ken
Old Feb 25, 2022 | 08:44 AM
zip439's Avatar
Default Re: Battery drain
Start the car, use your meter to read AC volts across the battery terminals. If you get any AC voltage the problem is in the alternator. If the alternator is good you should get no AC voltage.
sooperdave#69
Sep 10, 2014 09:28 PM
triplmmm
Aug 15, 2014 02:28 PM
chris1_uk
Sep 28, 2013 09:50 PM
MCG
Jun 5, 2012 12:44 PM
joe lonardo
Jul 1, 2010 07:22 AM
