Help with SRT serpentine belt
Old Jan 9, 2023 | 02:16 AM
sive81364's Avatar
Default Help with SRT serpentine belt
My SRT came with the NeedsWings Pulley Saver and my radiator hose blew and the serpentine belt came off and I had to pull belt off pulleys so I could remove blown hose and now after downloading all 4 different diagrams (which none are the same, some show7pulley (NA) and SRT 8 to 9 pulley) I am asking if someone can send me a diagram with the Pulley Saver installed.
Sorry was in wreck and know have issue understanding thing. I look at engine bay and pulley are not in the same place as in the diagram. The pulley is in different location some are close and some farther away than show on diagram. If I could get help with pulley labeled and if possible, maybe a picture showing belt position over supercharger and were it go after that. And I order new hose (upper house) but it's the wrong one. I found right one "expansion coolant reservoir hose" but only on Ebay but they are all used. Search the web and all sights say it was discontinued and help here to would be a great help.
Thank you for any help
Sive
Old Jan 9, 2023 | 03:50 AM
Sussudio's Avatar
Default re: Help with SRT serpentine belt
Sive
Here’s a print out of PSK with the corresponding new pulleys and belt rerouting
Real world pics from the forum
With the upgraded longer HD green belt
Let me know if you have anymore questions. Oh that hose you’re looking for I think Needswings has it, not 100 certain though.
Old Jan 9, 2023 | 04:42 AM
sive81364's Avatar
Thank you it all make sense now
Sive
Old Jan 12, 2023 | 09:13 AM
NeedsWings's Avatar
Default Re: Help with SRT serpentine belt
replacement belts
https://www.needswings.com/serpentine-belt-m112k
if you have a question about which supercharger or crank pulley you have, send me a picture and i can verify
replacement srt6 upper radiator hose
https://www.needswings.com/oem-upper...ose-slk32-srt6
Old Jan 20, 2023 | 03:35 AM
sive81364's Avatar
OK great news got everything back together but now have very bad noise coming from supercharger. I replace the pulley bearing because it was making noise and now it is making a lot of noise.
File Type: avi
Old Jan 20, 2023 | 11:47 AM
latemodel21's Avatar
Take the belt off and spin the SC pulley, if you get anything that sounds like what you have in the video, then there is probably a problem with the new bearing you installed (ie damaged during installation, etc). You can also spin (by hand) the supercharge side of the (pulley) clutch, this will let you spin the SC internals to further isolate the problem.
Old Jan 20, 2023 | 11:52 AM
With the engine stationary I presume for safety sake.
Old Jan 20, 2023 | 12:07 PM
NeedsWings's Avatar
yes, also did you put the thin shims back on the shaft to space the pulley away from the magnet ring?
Old Jan 21, 2023 | 12:36 AM
sive81364's Avatar
Did not have press to put new bearing in and went to local shop so do not know they replaced the bearing shim. I do know when they replaced the bearing the noise got better but still made a little noise.
ZERACER
Jun 4, 2020 11:31 AM
James1549
Feb 15, 2012 07:55 PM
wmphipps
Nov 8, 2009 09:23 AM
BEACHBUMAL
Mar 21, 2009 01:58 PM
3rdDan
Jun 2, 2008 10:50 AM
