Leaving Key in Ignition Switch
Old Dec 30, 2023 | 01:54 PM
Root66's Avatar
Default Re: Leaving Key in Ignition Switch
The real reason you do not spend so much time here is because there is nothing new.
It's a wonder there's anybody here considering the condescending replies from some.
Old Jan 1, 2024 | 10:21 PM
GannyX's Avatar
OK, I finally got around to it. My standby drain:
  • Key not in ignition two minutes after shutting car off - 17mA.
  • Key in ignition two minutes after shutting car off - 17mA.
Not a hard test to do and I already knew what the result would be, but it's always a good idea to verify before speaking.
I expected someone else to beat me to the punch, the fact no one did is part of why I dont' spend as much time here these days.
Sorry I was sleeping from my drive back from Florida (all nighter) but anyways, the only time it makes a difference is trying to lock the door while the transponder inside of the antenna ring . Car will not lock for 15-30 mins. ( I tested a bunch of time, why I against placing the Transponder inside for pushstart)
Old Jan 2, 2024 | 12:01 AM
Hay james give me a call..
have been leaving my key in the ignition for years n0o dead batt in fob or car,, once i turn the car off i remove the key then stick it back in the ignition, no ding ding nothing i left the V8 car thst way for 2 weeks, got it fired right up.
treyleblanc
Sep 17, 2024 06:26 PM
fastfred
Nov 5, 2018 09:47 AM
doug5639
Sep 11, 2011 10:19 AM
Marine05
Jan 25, 2011 08:00 PM
04chryslr
Dec 9, 2007 10:00 AM
