Replacing positive starter cable
Old Sep 4, 2024 | 06:18 PM
martiq100's Avatar
Default Replacing positive starter cable
I've searched everywhere for someone who has experience replacing the positive battery cable. Here's the backstory: my car began emitting smoke through the vents, and the lights wouldn't turn off. Fearing a fire, I called the fire department, and they cut the battery cables. The car has been parked for 8 years, but at the 6-year mark, someone diagnosed the issue in a forum as a faulty light module, which was also causing my problem. Now, as I prepare the car for its first start in years, I realize that replacing the cable is not as straightforward as it is in most vehicles. I'm seeking any pointers or advice on this matter.
Old Sep 6, 2024 | 02:57 AM
Default Re: Replacing positive starter cable
I haven't replaced the positive cable and hopefully someone who has will reply.
I would remove the battery if you haven't already. Then I would trace the original cable back to each connection. Take pictures of everything and connect the new one as you go along.
The service manual should have the information as well.
You can download the service manual here:
Service manuals, documents
I'm sorry that I can't be of more help.
Fuya
15
May 15, 2017 11:09 AM
yorktown4
Aug 31, 2012 03:23 AM
pizzaguy
19
Jan 1, 2011 10:40 AM
Alabaster04
Apr 1, 2008 05:29 PM
sparks81
Feb 18, 2008 07:55 PM
