Car will not start after a flat battery
Old Nov 7, 2024 | 04:44 AM
phenshall's Avatar
Default Car will not start after a flat battery
Hello,
I had a flat battery that was replaced okay and when i came to start the car all the lights on the dashboard came on but the car would not start.
I got the battery tested and a mechanic ran a diagnostic on the car who said it was the ignition. The key unlocks and locks the car and all the lights on the dashboard come on fine.
Does anyone know of a mechanic in the Manchester area who knows how to get my car started as no one will come out to look at it because it's a Chrysler Crossfire :-)
I am near the Manchester City football ground.
Getting a mechanic to look at my car appears to be a challenge whenever there's a problem.
Old Nov 7, 2024 | 08:49 AM
Default Re: Car will not start after a flat battery
Surprise, it is not a Chrysler, mechanically, it is a 2004 Mercedes SLK320. I would try changing the RCM, Relay Control Module. Seek help from an independent shop that works on Mercedes.
Old Nov 8, 2024 | 01:44 AM
Originally Posted by phenshall
Hello,
You might be better off posting your problem here: https://www.crossfireforum.org/forum/europe/
This will get responses and help closer to where you live.
When the battery was replaced, if the negative cable was connected first, then the positive, this may cause problems with the electronics.
It could be the Relay Control Module, you can get one for a reasonable price on amazon and try swapping it out and see if it starts. The RCM is located in the electronics box behind the battery. When you open the box, it will be the module closest to the engine.
You can also check your fuses and see if one has gone bad. There are fuses on top of the RCM that you can check as well.
One of our members, tighed1, is an RCM expert and has videos on youtube.
Here's a link for his videos:
RCM videos
Old Nov 26, 2024 | 09:50 AM
phenshall's Avatar
Hello,
I managed to get an electrician to look at it. He "waggled" the fuse box relay, and it started.
I have ordered a brand new one "Order confirmed: Mercedes-Benz Genuine Engine Management Relay Module Fits R170 A1705450305"
Thanks
Phillip
Old Nov 26, 2024 | 10:19 AM
phenshall's Avatar
Thank you for your reply and I think your post helped.
I am grateful for your help
Old Nov 27, 2024 | 01:49 AM
I'm glad that my post was helpful and that you were able to verify the problem.
Thank you for the update, and best of luck to you!
tmoore
Mar 8, 2019 06:09 PM
theglot
Mar 13, 2016 10:35 AM
fastfred
Aug 19, 2014 06:27 PM
dskul1
Feb 8, 2012 11:27 PM
vinny186
Nov 16, 2008 06:58 PM
