Bas
Old Mar 4, 2025 | 04:48 PM
Chooch's Avatar
Default BAS/ESP DTCs After HARD Braking
To prevent a near head-on collision, I REALLY stomped the brake pedal. Afterwards I noticed the BAS light now shining brightly.
I tried the full left, right, center reset without success,
Using my Scan Tool for an MB SLK 320, I got the following 7 ABS DTCs:
C1010-001 Terminal 87 undervoltage
C1140-032 N49 Steering Angle Sensor Coding Error
C1140-128 Steering Angle Sensor is not initialized
C1141-002 Pressure Sensor B34/1 ESP Electrical Fault
C1141-008 Pressure Sensor Zero Point Offset Error of Component B34/1 ESP Pressure Sensor 1
C1141-016 Pressure Sensor B34/1 ESP Pressure Sensor 1, B34/2 ESP Pressure Sensor 2: Plausibility Error
A7/7s1 BAS Release Switch Plausibility
I plan to start checking out why Terminal 87 has low/no voltage.
If I can get power restored, it may some or all errors. If not, ESP Pressure Sensor 1 is my next candidate.
Any thoughts oh wise and experienced Gurus?
Old Mar 4, 2025 | 08:50 PM
Default Re: Bas
Have you tried disconnecting the negative battery terminal for a few minutes?
Just an idea, but I wonder if that might reset everything?
Old Mar 4, 2025 | 09:27 PM
Wadsworth's Avatar
Default Re: Bas
Some people over the years have reset codes by touching the positive and negative cables together. I have never tried this myself.
Old Mar 6, 2025 | 11:15 PM
Default Re: Bas
Make sure the cables are physically off the battery, or at least one of them (the negative) is OFF THE BATTERY before they touch (ie: do not use another wire to make the connection while the battery is connected!
I would be quite surprised if anyone would touch them together with another wire but I have seen stranger things!
oli
Jan 28, 2022 10:54 AM
DHS
Jan 15, 2018 07:33 AM
meaty62
Jun 9, 2014 03:29 PM
xfchris
Jun 6, 2012 01:42 PM
Skyshadow
Nov 27, 2009 07:55 PM
