Can anyone identify this engine noise?
Old Mar 21, 2025 | 03:33 AM
red_2005_convertible's Avatar
Default Can anyone identify this engine noise?
Hi All,
I've had this engine noise now for quite a while, but I would like to know what it is. It sounds like a stick banging on a hollow wooden tube. I've tried to find it using my mechanics stethoscope, but no luck. It's not coming from the valve covers or water pump. Attached is an mp4 video with sound. I move the phone from the back of the engine on the drivers side to the front, around the front to the back of the passenger's side. It seems to get louder near the back of the passenger's side of the engine, but I'm not sure if that isn't me just moving the phone closer. It seems to go away at high rpm.
Thanks in advance, sincerely
-Jerry
2005 6 spd manual NA roadster limited
PS. to play the avi file I attached, I had to install a codex from the windows store into my media player, windows 10.
Old Mar 21, 2025 | 02:00 PM
zip439's Avatar
Default Re: Can anyone identify this engine noise?
I get a similar sound, most often after a hard run, and like you most pronounced near the rear passenger side. I assume it is the valve lash adjuster that sits between the valve stem and the rocker arm. It is not all that abnormal, but should be corrected if it is really bad. My car has 158,xxx miles.
Old Mar 21, 2025 | 10:25 PM
Hi Zip,
Thanks for the reply. My car has about 70,000 miles on it, but I do drive it hard sometimes. Tomorrow I'll be more thorough with the stethoscope, especially around the passenger side now that I have a hint that it probably is in the valve train.
-Jerry
austinbarrylee
Aug 19, 2022 03:48 PM
Siul
Apr 30, 2018 09:15 PM
Trenzman
Apr 27, 2014 03:41 PM
BlackCrossFire6spd
Oct 27, 2009 06:05 PM
Bob Brown
27
Apr 6, 2004 05:24 PM
