drive shaft
Old Apr 27, 2025 | 10:14 PM
flightmedic's Avatar
Default drive shaft
2004, I went to replace the center bearing. I have the correct new center bearing. I pulled the rear shaft section out of the car and installed the new bearing with no issues. When I went to put it back in the car the two will not go back together. Is there a special alignment I need to do on the splines? Or am I just missing something.
Old Apr 28, 2025 | 12:37 AM
Default Re: drive shaft
The best thing would have been to draw a line from the transmission to the differential with chalk before starting. this way you could line everything up when -assembling.
Look at the drive shaft halves wear the splines are. One side should have 2 marks and the other should have 1 mark. The the one mark lines up between the 2 marks.
Here's a link to the posts I did when I replaced mine:
LINK to driveshaft bearing re & flex disc replacement
Old Apr 28, 2025 | 05:37 PM
UnderTheSouthernCross's Avatar
How do you know when the driveshaft carrier bearing needs replacing? Are there any telltale noises etc?
Old Apr 28, 2025 | 06:50 PM
dcskmail's Avatar
Not matching up the driveshaft parts can result in vibration from being out of balance
Old Apr 28, 2025 | 07:27 PM
first the drive shaft is balanced "0" but there is a I (eye) single i on 1/2 and two II and the single goes between the two,,
there is nothing to show you that you have the line up but again the drive,, each1/2 of the drive shaft is balanced 0
I have used 1/2 from a srt6 and the other 1/2 from a limited. Blow this pic and u can see the notches.
Rear drive shaft/U-joint-p1010592.jpg
ok go to https://www.crossfireforum.org/forum...rive+shaft+amx.
then go to post 5,,,, blow up the pic the picture on the right. jim
Old Apr 28, 2025 | 07:32 PM
So, before I screw up everything. Where do I get a replacement driveshaft complete? Needswings only has a carbon fiber driveshaft. That is a bit more than I want to spend.
Old Apr 28, 2025 | 07:33 PM
I dont see the pictures.
thanks for trying though.
Edit..... I see the link and have seen the pictures. thanks.
Old Apr 29, 2025 | 12:57 AM
What's wrong with your driveshaft? If your having a hard time putting them together, I would suggest cleaning the splines and then applying long lasting silicon grease to them.
Make sure that the splines or spline receiver on both driveshafts aren't bent or obstructed.
New ones are available. I searched using a 2003 M-B SLK 320 and came up with these:
LINK Driveshaft ebay LINK - Driveshaft MB Parts Giant
The cheapest thing to do would be to take them to a driveshaft repair shop. You can have them cleaned balanced and test fitted for a third of the price of a new one.
Post some pics of what's going on with yours so we can better understand what trouble you're having.
Old Apr 30, 2025 | 12:26 PM
Nelson G's Avatar
Go here: https://www.wholesaleimportparts.com/
Old Apr 30, 2025 | 02:15 PM
Originally Posted by Nelson G
nice but NO srt-6 driveshaft.
Old May 1, 2025 | 03:42 PM
Nelson G's Avatar
Did you email them? They might show it, but I would check with them.
Old May 1, 2025 | 05:32 PM
Yep been talking to them 3 times today so far No driveshaft for srt6
about i had the u joint replaced in a drive shaft,,,never used the shaft because to
replace it takes a special tool to center and ping it the cost was $290. in 2015 .the tool also repairs the
drive shaft in some BMW's but the U joint is a different size it is centered and pinged with the tool jim
HappyHippy
Sep 26, 2024 10:45 AM
S0HDIUM
Aug 6, 2018 12:07 PM
MrMoPar
Sep 8, 2016 11:23 AM
Bucksnort
Apr 11, 2016 08:36 PM
