Another shifter problem
Old Jun 7, 2025 | 08:04 AM
Ny69ssdave's Avatar
Default Another shifter problem
I see a lot of people posting about their shifters, not being able to get them out of park and shift interlock problems.
my problem is it starts right up, but no gear indicator on the dash, no P, R, N,D. Just blank. It shifts right into gear but then locks. You have to shut the car off to move the shifter. Brake lights work. Any ideas? I did buy another shifter and same problem
Old Jun 7, 2025 | 08:58 AM
zip439's Avatar
Default Re: Another shifter problem
If the dash gear shift indicator is a black square you have a problem with the RCM or the TCU.
Here is a link to another thread on this forum. Read the entire thread It will help explain your situation: No gear indication
Old Jun 7, 2025 | 09:07 AM
Ny69ssdave's Avatar
Thanks zip! I will check the RCM. Difference is my car starts right up, goes into gear, but will not come back out of gear. But still no indicator next to the clock. Sounds like a new place to check
Old Jun 10, 2025 | 02:57 PM
red_2005_convertible's Avatar
Have you checked for codes. Might be a CAN BUS issue (P0600).
-Jerry
cruisedirector
Dec 8, 2022 12:05 AM
HellsAngel91
Aug 27, 2008 04:16 PM
manderson483
Aug 17, 2008 12:51 AM
Lumpacy
Dec 7, 2005 09:39 AM
