Automatic transmission issue
Old Jun 15, 2025 | 07:46 AM
JohnXfire's Avatar
Default Automatic transmission issue
Hi, I inspected a Roadster yestersay. I performed a short road test and while travelling at 30 mph it basically went into neutral and stayed for a bit. It was also lurching when starting from a stop. My searching indicates low oil level - perhaps I am wrong? When I was looking in the engine bay with a torch I noticed that there was oil around the black plug at the top of the bell housing. I don't know what that plug is for but I'm wondering whether oil can come out of that plug if there is a leak at the join of the torque converter and the transmission? The owner didn't seem to be aware of any oil leaks and there was nothing on his garage floor. He has had the car only 2 years and the car is not used much so perhaps the oil loss occurred under the prior owner?
Any thoughts?
Old Jun 16, 2025 | 02:04 AM
Default Re: Automatic transmission issue
Any thoughts?
The oil on top of the bell housing could possibly be leaking from the small breather covers on top of the valve covers. Ask the owner to remove the engine cover so that you can get a better look at them.
The fan blows the oil towards the rear of the engine. That's not a difficult repair if they are seeping oil.
Also look in the lower engine cover for oil. He may not have any leaks under the car, but there may be oil in that "belly pan".
The transmission problem could be low fluid or possibly a bad conductor plate. I have a manual transmission, so hopefully someone who has experience with automatic transmission will chime in.
Old Jun 16, 2025 | 06:54 AM
JohnXfire's Avatar
Thanks but it was literally only around that plug, it had not travelled down from the engine.
Old Jun 16, 2025 | 06:35 PM
Sorry about the confusion.
I guess I would have to see what you're talking about. The only "plug" I see on mine is the Crankshaft Position Sensor. It's located near the top of the bell housing on the left side (driver's point of view).
If there's a little seepage from there it's not a big deal.
Here's a picture:
Old Jun 16, 2025 | 09:52 PM
JohnXfire's Avatar
The photo in this link shows the black plug at the top of the bell housing where it meets the transmission
https://images.app.goo.gl/4L8SqKhphS44JoTL8
Old Jun 18, 2025 | 03:03 AM
Looks like some kind of vent cap in my opinion.
I don't have that on my manual transmission. Maybe @zip439 would know.
Blondie50
Oct 6, 2024 11:59 PM
SD Crossfire
Oct 24, 2022 07:50 AM
RoboJoe
Sep 22, 2013 10:20 AM
jamilleharley
Sep 28, 2009 12:04 PM
rjoyner17
Nov 30, 2008 12:36 PM
