NO POWER SEATS! 2005 SRT6 Coupe
Old Jul 3, 2025 | 04:04 PM
BoB Fenn's Avatar
Default NO POWER SEATS! 2005 SRT6 Coupe
Hi... I was never able to get a final answer from this group regarding the loss of my door locking function on my FOB. Okay... I live with it. But, now neither power seat will work. I checked the fuses and since there was NO power to either side of the fuse, I was "CONfused". I did find "some" fuses with power on both sides (good fuse), but the fuse numbers 21 and 22 for the two seats have GOOD fuses, but NO power, thus the seats do NOT operate. Oddly, there is also NO power to the wipers, yet they work fine! What the hell is with THIS???? What's the point of a fuse if it's not being used? If someone can help me here, that would be great. If not, then I'm going to go directly through from the battery over to the fuse box (through a 30amp fuse) and power it up with a clip... then see if I can move the seat. Any other suggestions? Thanks! BoB in Mass.
Old Jul 3, 2025 | 04:20 PM
Default Re: NO POWER SEATS! 2005 SRT6 Coupe
Are you using the fuse info included for your specific car in the fuse box? Not all crossfires are wired the same.
Old Jul 4, 2025 | 02:01 AM
Hi @BoB Fenn , most likely it is the power seat relay located behind the dash. This link covers how to replace it: Power seat relay replacement
Some things will not have power unless the key is in the on position. Like the wipers, brake lights, horn, etc... That might be why you're not seeing power on some of the fuses.
As far as the key fob, have you replaced the battery? If so have you done the re-sync procedure. The top battery in the fob might not be making contact with the prongs in the corner of the key fob.
Check out the video below:
Old Oct 20, 2025 | 05:15 PM
BoB Fenn's Avatar
Yes... looking at the ID list in the fuse box for the pwr seats. No POWER to either side of the fuse, so is there some relay in play here as well?
Old Oct 20, 2025 | 05:28 PM
Yes, the power seat relay. Use the search feature at the top L/H of part of the opening page.
Old Oct 20, 2025 | 05:41 PM
BoB Fenn's Avatar
I've searched both O'Reilly's and Auto Zone for this relay. BOTH stores offer TWO different relays. What's with this? O'Reilly's shows a 10amp and a 40amp. ???
Old Oct 20, 2025 | 05:53 PM
Needswings has the correct one:
https://needswings.com/power-seat-relay
Old Oct 20, 2025 | 06:42 PM
BoB Fenn's Avatar
Relay ordered... thank you SO much! Now, just to find a front bumper cover!
Old Oct 22, 2025 | 02:36 AM
If you don't find one listed in the market place, you can try ebay or LKqonline
j9xfr
U.K.
Feb 20, 2013 10:04 AM
Desert_srt
Nov 3, 2012 02:53 PM
Sheldon
Jul 28, 2011 09:58 AM
thededication
May 15, 2009 08:19 PM
Steven's Toys
Feb 19, 2008 12:28 PM
