XF Roadster 05/2007 Canbus splitter/devider location
Old Jul 5, 2025 | 03:02 AM
Equal2006's Avatar
Default XF Roadster 05/2007 Canbus splitter/devider location
Does anyone know?
First went locks, then roof, then climate now not starting
Old Jul 5, 2025 | 04:48 AM
Equal2006's Avatar
Default re: XF Roadster 05/2007 Canbus splitter/devider location
Hi!
Answering to my self. There is no spitters but nodes.....bad thing.
By the manual the locations are un clear
Does anyone know how they looks to find them?
Old Jul 5, 2025 | 08:31 AM
dcskmail's Avatar
You may find your answer here by doing a search : https://www.crossfireforum.org/forum...s-repairs.html
Old Jul 6, 2025 | 02:30 AM
Default Re: XF Roadster 05/2007 Canbus splitter/devider location
Originally Posted by Equal2006
Does anyone know?
Check your Central Locking pump. It is located under the trunk floor behind the right rear wheel well. It is a rectangular box covered with yellow foam.
Check for signs of water intrusion. Look at the connectors to see if they have any corrosion. If it does you will need to replace it.
There are no new units available so you will need to find a good used one.
Make sure to get about 18 inches of wiring with it. Water wicks up the wire and will cause problems in the future.
Let us know what you find. Good luck!
Old Yesterday | 07:49 AM
Equal2006's Avatar
Hi!
After 12 months XF is running again. Hell lot of work.
EMC and Skreem has deactivated. So any key will work. Locks can't work.....little problem.
Finally fuel pump failed and has now replaced. Cause tubes went out of fuel, I had to fill the system putting power directly to the RCM connector for a moment.
I bought used EMC, Skreem and a key from Latvia, an accident car....now only put everything back.
If someone has the same probem, I can sell deactivated EMC and Skreem....same price I paid....415 €......the taxes from UK are very high.
Old Yesterday | 08:27 AM
zip439's Avatar
Thank you for the information; Very glad you have saved the car and it is running again.
I believe you can get the locks working if you replace the central localing air pump locked in the truck.
This may help: Air Pump Replacement
Old Yesterday | 10:06 AM
Equal2006's Avatar
Hi!
After decoding Sreem and Mcu, the locks are not working cause locks are a part of the Sreem System.
In any case the car is running again.
Next tomorrow steering lock back To it's place and the interior back.
Every Year a lot of problems... 2021 the alternator started To burn.... It was close To the total...
2022 brakepedal went To floor... Abs pump jammed.
2023 RCM.. Repaired and again 2024 a new one.
Only 82.000 km. Staying In a garage for 7-8 monts/Year dosn't make good.
Let’s see, what is the Next problem...
Then replacing EMC and Sreem.
Adrian_X
Apr 3, 2015 03:00 PM
syfi
Mar 2, 2014 07:42 PM
smokey847
Dec 30, 2012 08:32 PM
kjwinston
Sep 24, 2012 07:21 PM
Mr Kilmouski
Mar 9, 2012 11:40 AM
