MAP Sensor and Vacuum Pipe Replacement
Old Aug 11, 2025 | 04:32 PM
PhilH's Avatar
Default MAP Sensor and Vacuum Pipe Replacement
Went to fit a replacement MAP sensor on my roadster today and when removing the original sensor I found that the end of the vacuum pipe that fits on the nipple on the rear of the sensor had become brittle and the end broke off when I tried to to pull it off. I just about managed to pull enough pipe to connect it to the nipple on the rear of the new sensor but it’s not on the nipple far enough for me to have confidence in the connection.
I guess after 20 years the vacuum pipe is passed its sell by date and I want to replace it. I had a go at tracing the route of the pipe to find out where its other end is connected to but didn’t have any luck as it’s routed through a sleeve with another pipe. From research it seems that the other end should be somewhere near the inlet manifold but this may not be the case.
Has anyone replaced this pipe? If so where should I be looking for its other end? Also, is the inner diameter of a replacement pipe 3.5 or 4mm and did you replace with heat resistant rubber pipe or silicon?
PhilH
Jul 31, 2025 10:16 AM
courtney_911
50
Nov 9, 2023 05:53 PM
chevyboyac
Jul 30, 2019 01:47 PM
Silverarrow
Jun 21, 2012 07:18 PM
sparks81
Jun 14, 2012 10:41 PM
