MAF Sensor Replacement
Old Jul 31, 2025 | 10:16 AM
PhilH's Avatar
Default MAF Sensor Replacement
I’m waiting for a replacement MAP sensor to be delivered which once fitted will hopefully cure my engine management light on problem with fault code dtc 0106
It would make sense to get a new length of vacuum pipe to replace the old pipe when the new sensor is fitted.
Does anyone know for sure the internal diameter of the vacuum pipe? Various sources I’ve found suggest 3.5 or 4.00mm but I’d like to be sure that whatever I buy has a snug fit
X-fired
Jul 11, 2017 03:37 PM
dom03
Apr 20, 2013 11:59 AM
maxime75us
Mar 28, 2013 02:42 PM
xfireon20z
May 17, 2012 03:07 PM
Mad_Med05X
May 11, 2009 08:43 PM
