Flashing symbol on odometer
Old Aug 24, 2025 | 09:51 PM
LLzel's Avatar
Default Flashing symbol on odometer
I get this flashing symbol when I start my car then it reverts to mileage.
any idea what it is
Old Aug 24, 2025 | 10:04 PM
copperfieldkid's Avatar
Default Re: Flashing symbol on odometer
The "double wrench" means you need service (check the manual) and the -20 means you're 20 miles past the service time; a double wrench means a more significant service interval (Schedule B) is due.
Maintenance of Oil displays on the Dash
#1 Checking Mileage left on the FSS PDF
#2 Checking Mileage left on the FSS PDF
Checking the Oil level via the dash display PDF
(Located in the Index of Crossfire problems and repairs)
Posted below is the Double Wrench Service
Old Aug 24, 2025 | 10:18 PM
Change engine oil, engine oil filter and rotate tires.
Replace dust filter
Lubricate hood hinges, latch and secondary latch.
Reset FSS Display
Check horn, hazard warning flashers, turn signals, indicator lamps, exterior lighting and headlamps (adjust headlight aim, if necessary)
Check windshield wipers and washer system. Replace wiper blades if necessary.
Check seat belts for damage and proper function.
Check hydraulic brakes and parking brake function.
Check fluid levels for hydraulic brake system, power steering system, windshield wiper system and engine cooling system (check corrosion inhibitor/antifreeze).
Inspect front and rear brake pads for lining thickness
Inspect tires for damage, general condition and inflation pressure. Correct if necessary.
Inspect major underbody and underhood components for leakage or damage. (If leakage is found, determine cause and repair)
Inspect condition of front axle ball joints and rubber boots.
Inspect condition of steering components and rubber boots.
Inspect condition of accessory drive belt.
Inspect body for paint damage (every 2 years)
Check chassis and supporting body parts for damage and corrosion (every 2 years)
Retighten steering locking bolts (50,000 miles or 4 years)
Check condition of driveshaft flex discs (50,000 miles or 4 years)
Replace fuel filter and air cleaner filter element (60,000 miles or 4 years)
Change the automatic transmission fluid and filter (80,000 miles). After this changes it is filled for life. Manual transmission comes filled for life from factory.
Replace spark plugs. (100,000 miles or 5 years)
Replace engine coolant using extended life coolant (100,000 miles or 5 years).
Old Aug 25, 2025 | 06:51 PM
LLzel's Avatar
Thanks for the information. I learned how to clear it.
Old Aug 26, 2025 | 09:01 AM
andy2m's Avatar
Thanks for posting the question. I have wondered the same thing for a while but had not gotten around to asking about it.
Old Aug 26, 2025 | 12:07 PM
All of this information is in your vehicle's owner's manual.
If you don't have one you can download it under the "TBS-and How Tos" section of the forum.
Old Aug 26, 2025 | 04:26 PM
LLzel's Avatar
That’s my next to do is read the owners manual. I got lazy
Stampede77
Jun 30, 2014 11:11 PM
BibaResto
Jan 1, 2014 11:21 PM
Chased316
15
Jul 18, 2010 04:12 AM
kingkub57
Jul 20, 2006 12:27 AM
The King
Apr 2, 2004 09:04 PM
