Detent Cable Kit (not bow tention cables)
Old Aug 29, 2025 | 08:50 PM
Nana's gone red's Avatar
Default Detent Cable Kit (not bow tention cables)
I have a 2005 Crossfire Limited and the Detent Cables on both sides are shot. I've looked under every rock. Last summer I put on new top and rebuilt the hydrolics $$$$, and now this. HELP!
Old Aug 30, 2025 | 09:43 AM
dcskmail's Avatar
Default Re: Detent Cable Kit (not bow tention cables)
Are you referring to the tonneau flap cables ? Some owners have had luck taking the old ones to motorcycle, boat, and bicycle shops that repair/build these type of cables also contact intruder351 here on the Crossfireforums here's his post, I rebuild them with your cable sheathing. However, in a few weeks, I will be making the entire flapcables from scratch. You will remove your flapcables and install the ones I’ll make. Not parts needed, no extra tools needed either.
I also make the bow tension cables. here's the link: https://www.crossfireforum.org/forum...post&p=1000316
Old Aug 30, 2025 | 10:40 AM
https://www.topsonline.com/products-...le=Convertible
Old Aug 30, 2025 | 11:21 AM
The part # is Detent Cable Kit (5170335AA) - #8 on the Crossfire top diagram (so you can see which one I'm needing. Not sure what your calling Flap Cable, if you could reference on d.iagram that would help5170335AA - : Detent Cable Kit for Mopar Image
xintersecty
Aug 23, 2024 09:34 PM
Jessiilynne
Aug 26, 2018 06:13 PM
FUBU
Mar 21, 2011 02:55 AM
Road King Custom
Apr 6, 2010 07:12 PM
