Roadster Detent Cable Replacement
Old Aug 22, 2024 | 08:41 AM
xintersecty's Avatar
Default Roadster Detent Cable Replacement
When releasing the latch on the top and pushing it up, it falls down. The problem is the cable that holds it up, has stretchered and can no longer hold the right length to hold the top. There is one reference in the manual, however is the usual brief description.
Detent Cable
We can't find replacement, but one of the members have created a batch. I was able to order from Charles.
Replacement Cable
The cable is routed through a strap on the second bow. You can not remove the cable through this strap without damage.
Retraining strap at second bow
Note this should be done at top replacement. Here is the instructions
Removal:
1) Unbolt the torx scew at the front bow. Place the brass spacer and screw in a safe spot. Don't leave it on top of the bow, you will forget and loose it. ( I know from experience )
2) Cut the strap off the spring. I started with cutters but had to switch to a razor and saw the material it's tough but should have been metal.
Might want to use a razor
3) using a razor cut the strap in half. This is so you can salvage the retaining strap on the second bow.
Cut you like a knife
4) Pull the material through the strap and remove the pin at the rear.
Note the plastic pin.
5) Using the replacement cable put the metal pin into the clip. Thread the cable through the retaining strap at the second bow. To put the new cable on the spring, use channel locks to slightly compress the spring at the end to slip on the cable.
6) Tilt the front bow to 45 degrees and hand thread the M8-1.0 Torx screw into the brass spacer back into the rubber bushing into the frame. (Too many intos?) Then tighten the bolt.
One side will not hold the top off, both sides have to be done before the top stays up.
Old Aug 22, 2024 | 02:27 PM
red_2005_convertible's Avatar
Default Re: Roadster Detent Cable Replacement
Hi Xintersecty,
Thanks for the write up. For now my Detent cables seem okay, but for future reference can you say what Charles's handle is so we can email him directly.
Thanks, sincerely
-Jerry
Old Aug 22, 2024 | 02:50 PM
Originally Posted by red_2005_convertible
Hi Xintersecty,
Thanks, sincerely
-Jerry
Jerry, I had to go back and really research how I found his information. Here is the link to the thread there I found his information. https://www.crossfireforum.org/forum/market/83483/page2
So I used his email and contacted him directly. He was very nice and the cables came quickly.
Crossfire forum handle clkashe
Email contact: clk@triad.rr.com.
Old Aug 23, 2024 | 09:34 PM
Hi,
Thank you for looking and providing his contact info.
-Jerry
martyn
U.K.
38
Aug 6, 2023 06:46 PM
danao91
Sep 3, 2021 01:50 PM
davelyoung1
Aug 17, 2020 11:16 PM
hamptondude
Nov 3, 2016 03:48 AM
