Car dies after approx. 15 miles travled
Old Sep 28, 2025 | 10:46 PM
ken38's Avatar
Default Car dies after approx. 15 miles travled
Car starts always when cold . After approx 15 miles it fades and dies. It will crank at this time with difficultly, but will not start. Waiting 46-60 minutes, the car starts and runs normally for a few more miles, then same problem is repeated. Does any of this sound familiar to anyone, if so please contact me. Thank you
Old Sep 28, 2025 | 11:15 PM
Default Re: Car dies after approx. 15 miles travled
A CPS. If you get one, get ONLY a BOSCH CPS. The generic have problems we all know of. Other members may chime in but it sounds like the CPS. Good luck!
Old Sep 29, 2025 | 02:04 AM
Hi,
most likely this is caused by a failing crankshaft position sensor. It's not hard to replace and you should always carry a spare as well as a spare RCM and the tools to replace them.
Here's a link to a post I did on how to replace the crankshaft position sensor: LINK - CPS replacement
Old Sep 29, 2025 | 10:50 PM
dcskmail's Avatar
Bosch crankshaft sensor , good price here also available on Amazon https://www.walmart.com/ip/Bosch-026...QaAr9EEALw_wcB
Old Sep 29, 2025 | 11:54 PM
ken38's Avatar
Thanks all- very helpful.
noticed that I had a sensor replaced recently, but it was the cam position sensor listed on the receipt, not crank sensor. Hopefully this will be the ticket.
cheers
Old Sep 30, 2025 | 12:55 AM
cheers
Keep us updated. Good luck!
Old Sep 30, 2025 | 09:47 PM
Jack G's Avatar
I would check the fuel filter. It might be on the ragged edge of being completely plugged and allows just enough fuel to get you 15miles.
Old Oct 2, 2025 | 06:41 PM
No704's Avatar
I was going to suggest a gas cap. Next time it occurs loosen the gas cap and see if it sucks in air.
Old Oct 3, 2025 | 07:18 AM
steve1189's Avatar
Simple diagnostic, keep a bottle of water in your car, go for a drive to replicate your issue. Pour the water on your cps, if the car starts replace the cps. Cheap and easy enough fix.
juddz
Jun 4, 2025 09:21 AM
amx1397
Apr 26, 2011 09:12 AM
jrf05
Mar 12, 2010 02:47 PM
reel adventure
Sep 9, 2007 07:47 PM
dobro
Dec 15, 2006 08:50 AM
