Key fob not locking doors
Old Sep 29, 2025 | 06:51 PM
Boudreau's Avatar
Default Key fob not locking doors
Hi all! As a new owner I'm curious to know why I can't remotely lock my car. It was suggested to change out the battery in the fob which I have done, but the car still won't lock. The lights go on when I press the lock on the fob but the car just doesn't lock. Any suggestions?
Old Sep 30, 2025 | 01:02 AM
Default Re: Key fob not locking doors
Hi, changing the batteries may have caused your key fob to go out of sync.
Make sure the the infra-red light is being emitted from the fob. Go into a dark room and push the button. See if you have a light coming out of the front of the fob.
If you do, then you can try to re-sync the key fob to the car.
Here is a video on how to do the process:
Old Jan 19, 2026 | 12:31 PM
Discourse's Avatar
Hey, I have the exact same issue. Recently picked up a Crossfire. My keyfob has the same problem. I replaced the batteries, have tried to re-sync and still no luck! The switch inside the car locks the doors okay, but otherwise I seem to be out of luck!
Old Jan 19, 2026 | 01:35 PM
It may be the locking pump in the bottom of the trunk got water in it. Which Crossfire model do you have and where are you located?
Old Jan 19, 2026 | 07:00 PM
Discourse's Avatar
Hmm, that could make sense? I can't lock the boot at all, just manually lock the doors. I'm based in the UK, the model is a 2004 Chrysler Crossfire 3.2 V6
Old Jan 21, 2026 | 05:20 PM
zip439's Avatar
When you open the door do the interior lights come on? If not replace fuse #9 in the under hood fuse box. the Central Locking Pump and the overhead lights are on the same circuit.
Old Jan 21, 2026 | 05:21 PM
Discourse's Avatar
The lights do come on when I open the door
tenger55
Oct 22, 2022 05:28 PM
nickwe21.
38
Sep 12, 2022 12:07 PM
Brady517
Jul 28, 2021 01:18 PM
dsdesigns
Feb 6, 2014 08:05 AM
an0nym0u5
Jul 22, 2008 05:56 AM
