View Poll Results: Is it the security system
Battery draining
100.00%
Car starts Stops after a short time. Eont restart
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Something draining battery.
Old Nov 19, 2025 | 09:30 AM
Lorab's Avatar
Default Something draining battery.
Something seems to be draining the battery. Itll start and run for a bit then die. If the battery gets disconnected it seems to reset. The mechanic seems to think its something to do with the security system. Hes at a loss anyone have any advice or insight??
Old Nov 19, 2025 | 10:38 AM
Default Re: Something draining battery.
Remove or replace the alarm siren under the cowl in front of the windshield. The internal batteries leak acid ad short out the circuit board. Clean the drains under the cowl while it is off. The search feature at the top R/H of the login page will give you lots of answers.
Old Nov 19, 2025 | 12:16 PM
I would also replace the RCM, it could be a failing relay.
Old Nov 20, 2025 | 10:01 PM
I would lean towards the RCM (relay Control Module).
The best thing to do in my opinion is take it to an auto parts store and have them check the electrical system. (Battery and alternator).
If you have someone near you with a Crossfire, you can try swapping it and see if the problem occurs.
You can also pull fuse #9 in the engine fuse box. That will disconnect power to the alarm siren to see if your battery drain starts.
Old Nov 21, 2025 | 06:02 AM
Lorab's Avatar
Thank uou for the advice. I will pass it on to my mechanic also does this involve the security system?
Old Nov 22, 2025 | 01:59 AM
Most likely the battery drain is caused by the car's alarm siren.
Here's my post on how to remove/replace the alarm siren: LINK-Alarm Siren Removal/Replacement
Here's my post on how to replace the RCM: LINK-RCM Replacement
MCPO
Apr 28, 2023 01:31 PM
JoXfire
Nov 6, 2021 09:43 PM
Twinve
Jun 17, 2021 02:54 PM
phil alvirez
Oct 2, 2019 11:09 AM
SRT SIX
Jan 28, 2012 03:42 PM
